Polar Analysis from flight logs?
Old December 24th 04, 08:38 PM
Mark Zivley
Default Polar Analysis from flight logs?
We all know what the manufacturer's polars look like, but what about our
individual planes. Has anyone done any work to develop a program that
would look at some flight logs and determine what a particular glider's
actual polar is? At one point Ball was making a vario system that would
determine the aircraft's polar over time just by flying.
For someone who already had some algorithms for computing wind from
ground track drift during thermals could take this info and then be able
to back figure from GPS ground speed what the IAS was during a
particular phase of the flight. By isolating longer sections of cruise
flight at varios airspeeds it should be do-able. Question is, has it
been done.
Mark
extra "hot" in the address to delay the spammers...
Old December 24th 04, 09:34 PM
Papa3
Mark,
How do you propose to isolate the impact of vertical air motion? For
instance, I can fly the ridge at 100Kts and maintain altitude (same for wave
or cloudstreets). I'm sure Rolladen-Schneider (ahem, DG) would love to
publish the L/D of my LS8 from the average of my flights for a season:
"LS8, with a measured L/D of 800:1..."
Cheers,
Erik
"Mark Zivley" wrote in message
m...
been done.
Mark
Old December 25th 04, 12:23 AM
Mark Zivley
Obviously ridge flight would not be conducive, nor wave, but put enough
data together from cruises during thermal flights and I bet something
could be put together.
Papa3 wrote:
Mark,
Cheers,
Erik
m...
been done.
Mark
Old December 25th 04, 02:58 AM
Eric Greenwell
our individual planes. Has anyone done any work to develop a program
that would look at some flight logs and determine what a particular
glider's actual polar is? At one point Ball was making a vario
system that would determine the aircraft's polar over time just by
flying.
able to back figure from GPS ground speed what the IAS was during a
cruise flight at varios airspeeds it should be do-able. Question is,
has it been done.
I haven't heard of it being done, and I can't imagine how one would
compensate for air motion, both vertical and horizontal, just using the
GPS info. Both motions change with location, altitude, and time. Perhaps
if the flight record included the airspeed, like some varios can supply,
there would be some hope of doing it. I don't think you could count on
the vertical motion averaging to zero during the cruises, since we
typically adjust our path to include as much up air as possible.
You can get some good info using a flight recorder, but you have to do
it when the air is calm. If you are really interested, invest in a few
high tows and make the measurements. Take a look at this test done on a
DG 800:
http://groups.yahoo.com/group/ASA-NewsGroup/message/59
You don't have to be a group member to read the message.
Eric Greenwell
Washington State
USA
Old December 27th 04, 03:13 PM
Richard Brisbourne
No it couldn't for exactly the same reasons ridge and wave don't work. In
typical thermal conditions air is going up and down all over the place.
Skilled pilots tend to fly in the good bits and ignore the bad bits.
Even if you could measure vertical and horizontal airspeed components,
"cruising" is likely to involve frequent speed changes, accelerations and
decelerations.
Papa3 wrote:
Mark,
wave
Cheers,
Erik
Old December 27th 04, 09:43 PM
Papa3
Mark,
My first post came across as a bit glib - apologize for that. But, I
actually put a little thought into that subject recently while writing some
batch analysis specs for GPS log files. The problem is that a good glider
pilot will not encounter random vertical motions - even in cruise flight.
He/she will stack the deck in his favor, seeking out cloud streets or
connecting the best looking individual Cu. Thus, you can't just average
out the L/D over time on specific segments (e.g. cruise flight). What you
can do is deterimine which pilot does the best job of achieving highest L/D
on a given day. Several of the popular flight analysis programs do this
already.
I'd certainly be interested in any detailed ideas you might have.
P3
m...
Papa3 wrote:
Mark,
wave
Cheers,
Erik
m...
been done.
Mark
Old December 28th 04, 03:20 AM
Bob Gibbons
On this topic of determining L/D from interthermal cruising, Dick
Johnson did a fascinating and underappreciated study in the late
1970's of airmass behavior between thermals. Dick flew in mostly blue
conditions and simply recoded his height loss versus distance covered
between thermals. Dick's results are reported in SOARING, June 1979.
Dick found that, on the average, the airmass between thermals has an
average sink rate related to the upgoing thermal strength. The
relationship Dick found was; the airmass sink is approximately 10% of
the lift strength.
I have always felt Dick's study explains why it is so difficult to fly
cross country (in a blue conditions) with a ship having an L/D less
than about 30:1. The probability of running into the next thermal
purely by chance becomes too low as the L/D drops.
For this discussion, I think Dick's study shows the inadvisability of
trying to deduce flight performance from interthermal measurements.
Bob
On Mon, 27 Dec 2004 20:43:41 GMT, "Papa3"
Mark,
already.
P3
om...
Papa3 wrote:
Mark,
wave
Cheers,
Erik
m...
been done.
Mark
Old December 28th 04, 04:12 PM
John Sinclair
I asked Dick Johnson, why couldn't I fly in calm conditions
(morning) and hold a given airspeed (say 60 knots)
and a given heading (say west) for 10 minutes, then
reverse heading to east (to cancel out any wind) and
then analyze the GPS trace to determine my ships L/D
at 60 knots. We have an accurate distance covered and
fairly accurate altitude lost, so why can't we crunch
the numbers?
Dick said the GPS info wasn't accurate enough. I thought
it was a good idea, but I defer to the master.
JJ
cruising, Dick
in the late
in mostly blue
distance covered
June 1979.
thermals has an
The
10% of
the lift strength.
so difficult to fly
an L/D less
next thermal
inadvisability of
measurements.
Bob
On Mon, 27 Dec 2004 20:43:41 GMT, 'Papa3'
Mark,
for that. But, I
while writing some
cloud streets or
flight). What you
programs do this
already.
might have.
P3
'Mark Zivley' wrote in message
. com...
and I bet something
Papa3 wrote:
Mark,
air motion? For
altitude (same for
wave
DG) would love to
'LS8, with a measured L/D of 800:1...'
Cheers,
Erik
m...
but what about our
a program that
system that would
wind from
was during a
sections of cruise
Question is, has it
been done.
Mark
extra 'hot' in the address to delay the spammers...
Old December 28th 04, 05:32 PM
Udo Rumpf
J.J.
That would be good enough for me.
In the end there is nothing like flying with a bunch of gliders
fairly close together after the last thermal of the day and 25-30 miles out,
to get a real sense of how your ship is doing.
Naturally you want know what the wing loading was of each glider.
In my case I would canvas the pilots of key gliders after to establish the
weights. I was fortunately to have had conditions were this worked out well.
An ideal contest was the Seniors with six glider on final glide all leaving
the last thermal at about the same time.
Regards
Udo
the numbers?
JJ
cruising, Dick
in the late
in mostly blue
distance covered
June 1979.
thermals has an
The
10% of
the lift strength.
so difficult to fly
an L/D less
next thermal
inadvisability of
measurements.
Bob
Mark,
for that. But, I
while writing some
cloud streets or
flight). What you
programs do this
already.
might have.
P3
.com...
and I bet something
Papa3 wrote:
Mark,
air motion? For
altitude (same for
wave
DG) would love to
Cheers,
Erik
m...
but what about our
a program that
system that would
wind from
was during a
sections of cruise
Question is, has it
been done.
Mark
Old December 28th 04, 06:34 PM
Eric Greenwell
the numbers?
How long ago did you ask him? GPS is much more accurate in the last few
years, especially if using the WAAS ablities. But, let's say you know
the distance to only +/- 100 feet (it's typically more like +/- 30
feet), then flying only a mile (5000 feet) would be a 2% error, or one
L/D point for a 50:1 glider. Good enough for us, I think.
If you use the GPS for the altitude instead of the pressure altitude,
you might have to fly off a 1000 feet or so of altitude, I suppose.
Maybe Dick was referring to GPS altitude?
Eric Greenwell
Washington State
USA
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 07:31 PM
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 11:20 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 08:13 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 03:13 PM
