This AD (2020-16-05) was just released with a mandatory compliance by 8/28:
https://rgl.faa.gov/Regulatory_and_G...E?OpenDocument SUMMARY: The FAA is adopting a new airworthiness directive (AD) for all Blanik Aircraft CZ s.r.o. Model L 23 Super-Blanik gliders. This AD requires a one-time inspection of the rudder control cable attachment screws and hinge bolts, replacement of the cable attachment screws and hinge bolts if a crack is found, and reporting the inspection results to the manufacturer. This AD was prompted by reports of cracked rudder cable attachment screws. The FAA is issuing this AD to address the unsafe condition on these products. |
On Friday, August 14, 2020 at 10:15:29 AM UTC-4, wrote:
This AD (2020-16-05) was just released with a mandatory compliance by 8/28: https://rgl.faa.gov/Regulatory_and_G...E?OpenDocument SUMMARY: The FAA is adopting a new airworthiness directive (AD) for all Blanik Aircraft CZ s.r.o. Model L 23 Super-Blanik gliders. This AD requires a one-time inspection of the rudder control cable attachment screws and hinge bolts, replacement of the cable attachment screws and hinge bolts if a crack is found, and reporting the inspection results to the manufacturer. This AD was prompted by reports of cracked rudder cable attachment screws. The FAA is issuing this AD to address the unsafe condition on these products. I should have mentioned it applies to all L-23's |
It’s a pretty easy AD to do. I talked to Vitek Siroky yesterday. He said so far there’s been no cracks found. The rudder has open bearings so it would be good to get them cleaned and greased while it’s off anyway.
To me (what do I know...), seems like doing the inspection....just replace the bolts....done deal, sign off...
Thanks for original post and link.... |
They’re pretty expensive parts. Dye penetrate is a lot cheaper. Not sure of the cost but some Blanik specialty bolts run $250....
Landing with broken rudder cable | [email protected] | Soaring | 26 | September 10th 19 08:39 PM |
Followup -- Rudder Cable Sleeve | Michael J. | Soaring | 0 | June 24th 12 07:11 PM |
Rudder cable slots | Ernest Christley | Home Built | 5 | July 1st 06 04:29 AM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Rudder cable - was The Little Wheel in Back | BD5ER | Home Built | 9 | September 11th 03 04:14 PM |
