Would someone please help me I want to know the dimensions and actual
individual weight of an LS4 ballast weight. I also want to know whether the material the weights are made of. (steel or lead). Cheers, Geoff. |
![]() Mine are lead. They are stamped 2.45 KG. They are 5.5 cm x 2.8 cm x 14.5 cm. The mounting hole in the center is approximately 1.7 cm in diameter and the hole is threaded. I hope that helps. Doug |
On Thursday, August 27, 2020 at 4:15:23 AM UTC+10, K8 wrote:
Mine are lead. They are stamped 2.45 KG. They are 5.5 cm x 2.8 cm x 14.5 cm. The mounting hole in the center is approximately 1.7 cm in diameter and the hole is threaded. I hope that helps. Doug Hi Doug, Many thanks for the info - just what I needed. Happy Soaring, Geoff. |
Looking for a set of ASK-21 ballast weights | kirk.stant | Soaring | 3 | September 14th 15 04:36 PM |
ASK-21 and Grob 103 cockpit ballast weights | kirk.stant | Soaring | 12 | September 2nd 15 08:57 PM |
Grob 103 Ballast Weights | Roger Fowler[_2_] | Soaring | 0 | January 16th 12 12:18 PM |
Lak-12 weights | pete83 | Soaring | 1 | June 26th 04 11:25 PM |
Lak-12 weights | pete83 | Soaring | 0 | June 26th 04 06:47 PM |
