Looking for a set of ASK-21 ballast weights
Old May 8th 15, 06:02 PM posted to rec.aviation.soaring
kirk.stant
Default Looking for a set of ASK-21 ballast weights
Our club (SLSA) has an ASK-21 that did not come with any front cockpit ballast weights (the lead triangles, and the 2 "bolts" that hold them in place under the pilot's knees).
If anyone knows of a set lying around unused, please let me know.
Thanks in advance,
Kirk
66
Old May 8th 15, 07:48 PM posted to rec.aviation.soaring
Per Carlin
Look for a local foundry that can cast lead. Make a piece of wood in the correct shape and they can make a set for half the original price from AS.
Old May 8th 15, 07:55 PM posted to rec.aviation.soaring
I use plaster to make molds, then melt lead fishing weights to make "weights". In this case, I would make a "wood blank" with the required dimensions (allowing a slight taper on the sides for a draft angle, lay the blank on a flat smooth surface (narrow side of the draft angle up)and pour plaster over the top of it & let harden. The draft angle eases removing the lead bit later & the mold should last for a number of casts.
In Kirk's place, he just needs the dimensions so he knows how big to make the mold (including depth).
Old September 14th 15, 04:36 PM posted to rec.aviation.soaring
Thanks in advance,
Kirk
66
Kirk,
Did you ever get your weights or cast your own?
Our club had a 112 pound club member and we needed weights. We cast our own and, back in 1/5/2012, I posted instructions on how we did the casting. You could cast your own, or as Per Carlin posted, you could pay a foundry to cast two weights for you.
Back when I did the casting, it was possible to obtain lead ingots from a plumbing supply company. I don't know if that is still possible, but with the advent of the US Post Office "if it fits, it ships" policy, you can now buy lead on ebay.
Each of the original 12 factory weights weigh 1 kilo. Since we have 2 ASK21s, we needed two sets of weights. The first time, we cast one 2" weight and two 1" weights. On the second batch, I decided that we did not need the fine resolution of 3 kilos, so I cast two 2" weights. The 2" thick weights came out to 6 kilos each.
If you want a pattern for either your own casting or for a foundry, email me directly with your address and I will mail one to you.
ASK-21 and Grob 103 cockpit ballast weights kirk.stant Soaring 12 September 2nd 15 08:57 PM
Grob 103 Ballast Weights Roger Fowler[_2_] Soaring 0 January 16th 12 12:18 PM
JSF/F-22 weights John Cook Military Aviation 2 September 11th 04 06:32 AM
Lak-12 weights pete83 Soaring 1 June 26th 04 11:25 PM
Can you mix oil weights? Ben Jackson Owning 13 January 5th 04 02:51 AM
