Hi;
We need to replace the dump valve seat in an LS4. This is the seat that forms the seal. The originals seem to have been made by Georg Fischer (+GF+) for a valve they no longer make. I believe that the +GF+ part number was 161 483 260. From my present understanding +GF+ cannot supply this item. I'm hoping that somebody here will know of an alternative source. These valves are used in a number of DG and LS gliders. Almost certainly any glider that is filled by pushing water up through the dump outlet uses this valve - e.g. DG 300, DG 505 some LS gliders. They are typically attached to ballast bags. |
SZD 55 water dump valve sticking. | Mark B[_2_] | Soaring | 0 | February 1st 19 10:15 PM |
Wanted: LS6-b tail dump valve | [email protected][_2_] | Soaring | 3 | August 13th 13 02:22 PM |
Solenoid valve for creating a tail ballast dump system...Lak17a | Sean Fidler | Soaring | 1 | March 30th 11 02:30 PM |
Solenoid valve for creating a tail ballast dump system...Lak17a | Sean Fidler | Soaring | 3 | March 28th 11 08:51 PM |
Dump valve for Ls4a | Robert Harvey | Soaring | 0 | November 20th 05 08:47 PM |
