Solenoid valve for creating a tail ballast dump system...Lak17a
Old March 29th 11, 04:27 AM posted to rec.aviation.soaring
Sean Fidler
Default Solenoid valve for creating a tail ballast dump system...Lak17a
Thank you all for the good advise and idea's.
Sean
Old March 30th 11, 02:30 PM posted to rec.aviation.soaring
seventripleone
You'll definitely want at least a mechanical backup for the valve if a
full tail ballast can put your C of G really aft of the normal range.
(I have flown with an overfilled tail ballast through sheer arrogance
and wouldn't want to repeat that.)
The Schleicher valves are notoriously prone to problems with the
connectors and almost all other parts of the system and a blown fuse
gets you zero volts which is less than the required 5V... (I have
flown an ASH25 full of water where one of the valves didn't open and
Do yourself a favor and copy one of the mechanical systems.
Solenoid valve for creating a tail ballast dump system...Lak17a Sean Fidler Soaring 3 March 28th 11 08:51 PM
Ballast dump time Discus J. Nieuwenhuize Soaring 7 April 27th 07 05:56 AM
Dump valve for Ls4a Robert Harvey Soaring 0 November 20th 05 08:47 PM
Schemp Hirth water ballast dump valves tango4 Soaring 14 September 2nd 04 07:13 PM
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 11:02 AM
