I have a very strange interference problem with my
LX5000 and Becker AR4201 radio: when I transmit, the LX5000 changes pages, menus and inputs on its own. The funny thing is that if I hold the PTT and keep silent, nothing happens: problems come when I start modulating (talking). The wiring has been double checked and found ok. The two instruments are placed very close together, with the LX directly above the radio, and virtually no space in between. The panel is carbon fibre. The microphone is of the panel mount type, but insulated from the panel surface. LX Navigation could not find a solution so far. A friend suggested I wrap the LX in a fine brass mesh and connect this to GND (to shield it from electromagnetic interference), but I am unsure. Any competent suggestions? Thank you, cheers Flavio |
The Becker transmitter is probably transmitting properly. The problem is
that the LX5000 is acting as a receiver and when you transmit you cause the interference. Such interference is not uncommon among electronic devices. You LX5000 is not supposed to be a receiver, but transistors and diodes can act as a crystal radio receiver and develop voltage when you transmit. In this case, the audio "demodulated" by the diode rectifier (or transistor or ic acting as a diode) is developing the voltage and causes the interference. What you need to do is to prevent the transmitted signal from getting into the receiver. This is often a "keep working at it until it stops" approach. Start with using shielded wires for each of the leads of the LX5000. Then, add ferrite beads (can be clip on type available from Radio Shack) over each of the wires as they come into the LX5000. If that does not work, shield the leads also to the Becker - in particular the supply line and headset. If none of that corrects the problem, then the LX5000 could be picking up directly from the Becker antenna - which means that the Becker antenna must be shielded from the LX5000 and/or a greater distance created by moving the antenna (possibly to the tail). Persistence, perserverence and an occasional beer (not before flights) should get it solved. Colin |
| GPS / radio interference | Cub Driver | Piloting | 2 | October 31st 04 11:57 PM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 10:10 PM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 10:10 PM |
| Speaking of interference (BPL) | Roger Halstead | Instrument Flight Rules | 3 | November 8th 03 05:06 PM |
| radio / vario interference - HELP! | Chris Davison | Soaring | 13 | November 3rd 03 07:09 AM |
