Speaking of interference (BPL)
Old November 7th 03, 10:34 PM
Roger Halstead
Default Speaking of interference (BPL)
I don't know how many are aware of the current push to implement
Broadband Power Line (BPL) high speed internet connections, but is has
some interesting ramifications.
Perhaps Jim has looked into this.
BPL as I understand it caused a good deal of interference from a bit
above the AM broadcast band to the lower VHF frequencies where it was
tested. The companies pushing BPL claimed they had no interference
(in some carefully selected areas, some with only 10 homes), yet
independent testing showed that they did.
My concerns a Should we as pilots be concerned as to what this can
do to our nav radios? What about an ILS which is on the bottom of the
aviation frequencies.. NDBs which are at the other end of the
spectrum?
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
Old November 7th 03, 11:14 PM
Teacherjh
Yeah, I think so. More benign stuff (cable TV lines) messes up my car radio,
sometimes to the point I can't use it and would be forced into a satellite
radio subscription if I weren't against it on principle, let alone against
being forced into it by the same forces that benefit.
BPL makes no sense to me - power lines are filtered to get rid of the HF stuff,
and that's exactly what broadband needs.
Maybe five miles up it's no biggie, but on approach, when you -really- need it,
that's when it'll bite you. I think this is a far bigger problem than
cellphones on airlines.
Jose
Old November 8th 03, 07:46 AM
Roger Halstead
On 07 Nov 2003 23:14:56 GMT, (Teacherjh)
You need to get a few hams to drive around running 2-meter mobiles.
It wouldn't be long and the cable leakage would get cleaned up.
I've only seen a few cases of bad cable leakage. When it leaks that
bad it usually bothers reception as well and customers complain.
On occasion I listen on 145.25 MHz which is an amateur frequency. It
also happens to be the audio subcarrier for cable channel 18. I did a
demonstration over in the city of Alma MI for the cable company. With
my HT I could blank all their monitors in the distribution center
which of course blanked everything to their customer base as well.
They remarked that it was only because I was so close. So I went out
to my car which was well over a 100 yards to the west. The HT was
still bothering a little, but when I keyed my mobile station their
whole system went blank. When I came back into town the next day
nearly all the leaks were fixed. The following day I could not find a
one.
One thing that bothers them is customers who hook up an outside
antenna without using a switch. It leaves the antenna tied to the
cable and it does a really good job of picking up amateur radio on
2-meters which then gets fed to all customers down the line.
I'd complain to the FCC. They are pretty good at coming down on cable
companies who are reluctant to keep things fixed.
That's the part that worries me. They may be able to filter out the
FM and aviation bands. The cut off is *supposed* to be below the FM
broadcast band, but high speed data with steep rise and fall times
develops some pretty strong harmonics, even if it is spread spectrum.
OTOH, I'm assuming if they use the same HF frequencies as the ham
bands it will only take one or two running high power to cause
problems to BPL. (again, even if it is spread spectrum)
In a number of states the State Police still use some frequencies
around the 40 to 50 MHz range.
Jose
Old November 8th 03, 04:06 PM
Some of us drive considerable distances causing us to subscribe to satellite radio
for reasons far more beneficial than avoiding neighborhood RF interference.
Magneto/comm interference on TKM MX-R Narco 120 replacement Eugene Wendland Home Built 5 January 13th 04 02:17 PM
Speaking of Interferrence (BPL) Roger Halstead Home Built 3 November 8th 03 11:09 PM
Speaking of Cooling Larry Smith Home Built 4 September 23rd 03 07:59 PM
Speaking about Sonerai's................ Vincent Vega Home Built 4 September 15th 03 10:16 PM
