Does anybody have any suggestions for this problem?
At the moment I run version 1.2.4.7. NMEA source is my LX-20. I have hard-reset the unit, and installed only GPS_LOG (on a dedicated Ipaq 3130). NMEA sentence is set to RMC, 4800 bps. enjoy the sky Aldo Cernezzi |
Question is does anyone with similar configuration have the same
problem. You did not provide enough of a description for me to attempt to help. Let's communicate directly. I need a definition of "freezing". How often does it freeze and under what circumstances? Does it freeze if you use just a standard GPS? Is "RX_FLAG" off.... Regards, Henryk Birecki cernauta wrote: Does anybody have any suggestions for this problem? At the moment I run version 1.2.4.7. NMEA source is my LX-20. I have hard-reset the unit, and installed only GPS_LOG (on a dedicated Ipaq 3130). NMEA sentence is set to RMC, 4800 bps. enjoy the sky Aldo Cernezzi |
Henryk Birecki wrote:
Question is does anyone with similar configuration have the same problem. You did not provide enough of a description for me to attempt to help. Let's communicate directly. I need a definition of "freezing". How often does it freeze and under what circumstances? Does it freeze if you use just a standard GPS? Is "RX_FLAG" off.... Thank you very much for your interest, Henryk. I tried today, once more. With another Ipaq (3630). It freezes in thermals. Not in straight flight. Just a few circles, and the blinking symbol will stop blinking, the Ipaq won't respond, I'll soft-reset. After the flight I have checked the NMEA settings on my LX20. There were probably too many activated sentences. Disabled all of them except RMC. Will this cure the problem, next flight? Never tried with a standard GPS, just the LX20. I'll check for the RX_FLAG to be off. I'll post the results. Thank you! Aldo |
Just an idea.
I am using GPS-LOG an IPAQ 3630 and an HICOM HI-203E GPS Receiver. Usually it works fine and i am very satisfied. I had one, maybe two situations when GPS LOG freezed in flight while thermaling and i had to make a reset in flight. This occured first when i started using the gps receiver in my Libelle 201B. Before this the receiver was fixed in an Astir CS77 on top of the instrument board (behind the compass) and i never had any problem. In the Libelle I have the receiver in a rather low position behind the pilot seat on the right side in the cockpit (yes, i will improve this). I guess the the gps receiver looses signal while left-circling because, there is to much of the wing between the receiver and the sky so the signal strenght is not good enough. If I look at the logfiles, there are some / very few strange pikes, which also makes me think that i loose the GPS signal. Ruediger |
Issues around de-ice on a 182 | Andrew Gideon | Piloting | 87 | September 27th 05 11:46 PM |
My first freezing rain encounter | [email protected] | Piloting | 21 | January 6th 05 03:44 AM |
