spinner backing plate
Old October 10th 04, 02:50 PM
Ray Toews
Default spinner backing plate
I scored a free spinner in good condition but the backing plate is
gone, any body know what type and thickness of material I would use to
make a new one?
Ray
Old October 11th 04, 12:23 AM
Orval Fairbairn
make a new one?
Ray
It really depends on the spinner and prop in question. Some backing
plates are of complex shape and usually are .065" or more thickness.
The frontplate is just as important as the backplate, too.
Old October 10th 04, 07:19 PM
Ray Toews
I measured a few others and they seem to be between 50 and 65
thousands thick, I am going to try spinning it on a lathe and forming
it that way but am not sure what alloy to use, I think 2024 but if
anybody knows it would be appreciated. I have searched on the net and
found nothing under propellor spinner. Does it have to be heat treated
after forming or is it better left soft.
I have a front plate which I will be matching to the spinner,,,,I know
it would probably be more advisable to just buy one but I like to try
new things and spin forming a new back plate sounds interesting.
Ray
On Sun, 10 Oct 2004 23:23:03 GMT, Orval Fairbairn
make a new one?
Ray
Old October 11th 04, 03:04 AM
Cy Galley
What diameter is the back of the spinner? How many holes?
Ray Toews wrote in message ...
Ray
make a new one?
Ray
Old October 11th 04, 01:19 PM
Ray Toews
About 12 inches, depending on final fit and how far into the spinner
I recess the backing plate, I have allready cut the spinner down about
2 inches as it was too big . Anywhere between 10 and 12 inches would
look good on the airplane and fit between the cooling holes in the
nose bowl. Probably six screws between each blade so 12 fastening
holes.
Thanks
Ray
On Mon, 11 Oct 2004 02:04:27 GMT, "Cy Galley"
Ray
make a new one?
Ray
Old October 14th 04, 01:16 AM
Dick
Ray,
How did you cut the spinner down and keep things square?
Thanks, Dick
holes.
Thanks
Ray
Ray
to
make a new one?
Ray
Old October 11th 04, 06:29 PM
Orval Fairbairn
5052 or 6061 would be more appropriate, as they are weldable. Use a low
temper, as the stuff will work harden.
striped spinner Pianome Home Built 1 July 4th 04 09:56 PM
spinner fab Dick Home Built 5 April 23rd 04 02:26 AM
spinner fab Dick Home Built 2 April 14th 04 12:21 AM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Home Built 4 March 11th 04 11:31 PM
