spinner fab
Old April 14th 04, 11:57 PM
Dick
Default spinner fab
Dan,
Thanks for reply. I was at Sun 'n Fun today and after talking with the
"metal fab" guys, was giving up on a domed metal spinner (at least fabbed by
me G).
If you could answer a couple of more question....
Tomorrow I'll check those 172 spinner backplate but don't understand how you
handled the "point" of the spinner?? Approximately what was your base
diameter and length?
Do I understand that instead of a front bulkhead, you used those steel
brackets connected to the prop?
Thanks again, Dick Ripper
----- Original Message -----
Newsgroups: rec.aviation.homebuilt
Sent: Tuesday, April 13, 2004 7:21 PM
Subject: spinner fab
(JDupre5762) wrote in message
anyone have any experience with fabbing a large spinner; say 16" od and
18 "
long?
I made one for a Soob in a Glastar, using 5052H32 and cutting two
circle segments that I rolled and riveted together. Could have done it
with one piece but a single rivet line would have imbalanced it. The
aft bulkhead was formed from the same stuff over a plywood template,
with notches to allow the compounding (see a 172's spinner backplate)
and the front mounts were welded steel brackets that bolted to the
blade bolts of the Warp Drive prop. It ran fine, still does.
Dan
spinner fab Dick Home Built 2 April 14th 04 01:21 AM
