I use a Cambridge Model 20 logger and Cambridge Pocket Nav running on a
Compaq Aero 1520 (yeah, I know, I'm several versions behind on software and hardware, but I'm a creature of habit). Anyway, I'm sick of the little red mark next to my OLC claims. I'm not willing to pack my laptop for everyday trips to the airport, and the Model 20 is securely tucked away under my glareshield, so direct access to the serial port is inconvenient. What are my options for a download using just the Compaq 1520? I'm basically not willing to jump through any hoops, so it needs to be something that runs natively on the Pocket PC OS. Oh, and it should be free :-)) Thanks, Erik Mann (P3) |
I use a 2110 Compaq Aero which is the color version
with GNII and a model 20. When closing the program at the end of a flight it asks if I want to down load the flight log. When the down load is complete it indicates if file security is OK. The file is stored in the 2300 for later download to the home computer. At 23:00 08 May 2005, Papa3 wrote: I use a Cambridge Model 20 logger and Cambridge Pocket Nav running on a Compaq Aero 1520 (yeah, I know, I'm several versions behind on software and hardware, but I'm a creature of habit). Anyway, I'm sick of the little red mark next to my OLC claims. I'm not willing to pack my laptop for everyday trips to the airport, and the Model 20 is securely tucked away under my glareshield, so direct access to the serial port is inconvenient. What are my options for a download using just the Compaq 1520? I'm basically not willing to jump through any hoops, so it needs to be something that runs natively on the Pocket PC OS. Oh, and it should be free :-)) Thanks, Erik Mann (P3) |
Gary,
Pretty much the same as I do with Pocket Nav. It also indicates security okay. For some reason, the Cambirdge software (this pre-dates GNII) doesn't insert a G record. I get the A record, H records, a single-instance I record, L records, then all of the B records. But, no G. I should clarify that I KNOW that a "legitimate" G record can only be produced by the Cambridge authorized DLL; what I was hoping for was that somebody had created a Pocket PC download application that invoked the appropriate DLL, suitably packaged for running on Pocket PC. I simply refuse to deal with the bull**** of having to lug around a laptop (which no longer has a serial port, so add on to that the USB to Serial adapter) to bring over to the glider or deal with the fact that repeatedly plugging/ unpluggin RJ 11 connectors eventually leads to their failure. For now, I guess I'll just live with the stigma of the scarlet I ("Info") on the OLC site :-)) P3 |
GNII, and I think the old Pocket NAV download the *.cai file and then
generate the *.igc file from that. The *.cai file is what you need to use for the OLC if you don't want the red mark. The one you have on the PDA will work just fine. It doesn't help to have a laptop for the download, unless you just want to check the log on the spot. You need to use the OLC utility (available on the OLC site for free) or the equivalent in SeeYou and maybe others to generate the *.igc file to give to the OLC. The utility encodes the *.cai file as ascii text and appends it to the generated *.igc file. That allows the OLC to verify the security of the submission using the original *.cai file. The utility runs under DOS, but it doesn't have to be done at the time of the download. The OLC does not accept the old fake G record on old heritage CAI loggers any more. It doesn't help to have a laptop for the download, unless you just want to check the log on the spot. You don't have to accept the red dot, if you don't mind a few hoops once you get home with your log file (*.cai) on your PDA. ZL Papa3 wrote: Gary, Pretty much the same as I do with Pocket Nav. It also indicates security okay. For some reason, the Cambirdge software (this pre-dates GNII) doesn't insert a G record. I get the A record, H records, a single-instance I record, L records, then all of the B records. But, no G. I should clarify that I KNOW that a "legitimate" G record can only be produced by the Cambridge authorized DLL; what I was hoping for was that somebody had created a Pocket PC download application that invoked the appropriate DLL, suitably packaged for running on Pocket PC. I simply refuse to deal with the bull**** of having to lug around a laptop (which no longer has a serial port, so add on to that the USB to Serial adapter) to bring over to the glider or deal with the fact that repeatedly plugging/ unpluggin RJ 11 connectors eventually leads to their failure. For now, I guess I'll just live with the stigma of the scarlet I ("Info") on the OLC site :-)) P3 |
Dave,
Muchos gracias. I'll try that tonight. P3 |
Go to this page
http://www2.onlinecontest.org/validate.php FM Papa3 wrote: Dave, Muchos gracias. I'll try that tonight. P3 |
| Thread Tools | |
| Display Modes | |
| WTB: Sage Model B Netto Total Energy Box | November Bravo | Soaring | 0 | March 15th 05 04:10 PM |
| Model Building (but not with plastic and glue) | [email protected] | Soaring | 7 | March 3rd 05 05:01 AM |
| Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 05:03 AM |
| FA: 5 Airplane Model Kits - Bomber, Jet, Warbird | Disgo | Aviation Marketplace | 0 | February 22nd 04 06:00 PM |
| FA: Bomber Plane Model MIB - Monogram 1/48 HEINKEL | Disgo | Aviation Marketplace | 0 | February 21st 04 03:40 PM |
