Model Building (but not with plastic and glue)
Old February 5th 05, 12:47 PM
Default Model Building (but not with plastic and glue)
To continue to my discussion with Burt... ;-)
As noted in the previous thread, we all need to build an aerodynamic
model to inform our decision making process. I'd like to offer up some
notions that might make examining these models a little easier:
First, a model is only as good as its ability to predict outcomes
accurately.
Second, all models are flawed.
Third, a model for airmanship is only useful if it allows quick
reference and quick action.
Fourth, a good model does not purport to tell the truth.... that is the
realm of philosophy.
Fifth, an aviator's model will be very different from an engineer's
model; however, they should not vary in substance, only in application.
Sixth, because of the third point, it will be necessary to create a
system of simplified models. None of these models should conflict in
substance or application.
The object here is to agree that because all models are artficial
constructs, they are all flawed, and therefore, all open to
improvement. So the comment, "Your model is flawed..." should be
universally acceptable. "Of coruse it's flawed. It's a model." Then we
can get on with the business of whether a particular element can stand
improvement.
Let me introduce a last notion to help the discussion along. One model
that borders on axiomatic is F=ma. If a aircraft is subject to an
unbalanced force (Fnet does not equal zero), the aircraft will must
accelerate: that is, it must be changing its speed or direction. If a
force is acting on an aircraft it must accelerate. Try integrating that
with some of your models to see if they suffer.
(Yeah, I know... hurry up spring!)
Old February 8th 05, 12:42 AM
OK, maybe this is too esoteric. Let me ground it. I have often heard
professional pilots say that a side slip is used to counteract the
force of the wind. This comment implies a model in which the wind
applies a force to an aircraft in flight and that the horizontal
component of lift of the tilted wing (in a slip) allows the aircraft to
fly straight.
While this model works, it is flawed (as all model are). But is there a
better model to be had? The problem with this model is that it is not
compatible with other models. For instance, F=ma. If the wind applies a
force to an aircraft in flight, where is the acceleration?
The obejct here is to deconstuct some of our more cherished models to
see if there is room for improvement. And remember, there are very few
universal models. Most have subtleties based on who taught you, what
books you've read, your own experience...
Old February 8th 05, 08:52 AM
Marian Aldenhövel
Hi,
The wind applies a force. That force is cancelled by the horizontal
component of lift. So the net force is zero and the acceleration turns
out to be zero too.
If you like to you can also calculate two accelerations. As the mass
stays the same those would cancel each other in the same way.
Ciao, MM
Marian Aldenhövel, Rosenhain 23, 53123 Bonn. +49 228 624013.
http://www.marian-aldenhoevel.de
"Wir brauchen keine Opposition, wir sind bereits Demokraten."
Old February 8th 05, 01:59 PM
If the wings are level, then, the wind applies an unbalanced force?
Please show me the resulting acceleration (changing speed and/or
direction) that results during wings level flight. Remember, so long as
the force remains unbalanced, there will be a continuous change of
speed and/or direction.
Does everyone see the problem with this model of crosswinds?
Marian, thanks for responding.
Old February 8th 05, 02:57 PM
Marian Aldenhövel
Hi,
If you start from an aircraft at rest or one that enters the crosswind
suddenly from a crosswind-free area (all theoretical of course) it will
be accelerated sideways. You can feel that. F=ma holds true.
Remember, so long as the force remains unbalanced, there will be a
continuous change of speed and/or direction.
The F is only non-zero until the wind has accelerated the aircraft
sideways to it's own speed. After that you move sideways above ground
but the crosswind does no longer excert force on the aircraft and so
the acceleration stops.
If you want to keep a straight track over the ground in the face of
a crosswind you need to accelerate into the wind. To do so you bank,
the horizontal component applies an F to the aircraft, you accelerate.
At this moment the aircraft can "feel" the wind and you get your F_wind
back.
If you bank by just the right amount this F and the F_wind balance each
other at the exact point where you travel above ground in the direction
you want to go.
I don't.
Ciao, MM
Old February 8th 05, 08:33 PM
Marian,
read Todd's post. He works through it nicely. I've commented on it as
well.
Repairing Plastic Interior Parts of 40-year-old Aircraft jls Home Built 6 December 7th 04 10:04 PM
Repairing Plastic Jay Honeck Owning 5 February 2nd 04 09:20 PM
Drywall Gussets Veeduber Home Built 5 October 27th 03 09:03 PM
