I'm considering the purchase of a Navman 3450 for use with an iPAQ
3765. I want the unit primarily for the auto navigation software. That I can also use it with WinPilot is nice as well. (that way I'll have two GPS's whilst flying) Unfortunately, the user reviews for Navman are not very good. The primary problems seem to be difficulty acquiring and keeping satellites and software given to "freezing up" and requiring reboots of the iPAQ. I can't believe acquiring satellite will be a problem in the glider but I can see where it might be in the car. There are other options for use with a PDA but none I've found for use with the 3700 series. Does anyone have experience with the Navman 3450? I guess I could just throw the iPAQ out the vent next time I fly and start all over with a better PDA and better navigation software. Doug |
Doug,
I know nothing about the Navman but I did buy a compactflash slot GPS receiver that I use with the IPAQ sleeve as a backup receiver to my 302. It works with WinPilot Advanced, you just have to find out which COM port it uses (mine works with COM 4). A compactflash GPS receiver can be had on ebay for under $100 and the sleeve for the IPAQ goes for $25. If you add an external power supply box (another $10 plus 4 AA size NiMH batteries) your IPAQ is a stand-alone powerful soaring computer. My no-name receiver has the Model number BC-307, go and google it. Never drops 3-d reception and seems to have a reasonable power drain. My IPAQ is a 3955. Herb, J7 Doug Snyder wrote: I'm considering the purchase of a Navman 3450 for use with an iPAQ 3765. I want the unit primarily for the auto navigation software. That I can also use it with WinPilot is nice as well. (that way I'll have two GPS's whilst flying) Unfortunately, the user reviews for Navman are not very good. The primary problems seem to be difficulty acquiring and keeping satellites and software given to "freezing up" and requiring reboots of the iPAQ. I can't believe acquiring satellite will be a problem in the glider but I can see where it might be in the car. There are other options for use with a PDA but none I've found for use with the 3700 series. Does anyone have experience with the Navman 3450? I guess I could just throw the iPAQ out the vent next time I fly and start all over with a better PDA and better navigation software. Doug |
I am using the Navman pin navigation it crashes when crossing the border due
to loading another states map database and crashed a few times on my 1400 km trip to Adelaide and my 1000 km trip back to Temora. I have not been able to get strepla to run on it demo of winpilot runs. http://www.navman.com/go/aus/product...x.html#gps3450 |
I have a Navman 3450 and don't like it much. Haven't used it in a
while. Coincidently I have an iPAQ 3955 for sale, used but still in the box from the guy I bought it from through amazon.com, I'll prolly put it up on ebay soon and cut my losses. ted/2NO |
At 01:00 10 May 2005, Doug Snyder wrote:
Does anyone have experience with the Navman 3450? I guess I could just throw the iPAQ out the vent next time I fly and start all over with a better PDA and better navigation software. Doug I own one and it sits in a drawer in my garage. I used it a few times for car navigation and once for flying with WinPilot Advanced (at the time it didn't work with Pro - I don't know about now). It has some shortcomings - especially compared to units based on newer GPS chipsets. First, its Time To First Fix (TTFF) is awful. In many cases even in open space it would take tens of minutes to get a fix (some times never). This is in part because it has no memory of where it was last or where the satellites ought to be so every time you power it up it does a random satellite search. Second, it doesn't seem to hold a fix well at all. When I flew with it it got lost frequently. This is not a good thing to happen on a marginal final glide. Third, it will suck its rechargable batteries dry in about 45 minutes, so you better have a good source of external power. The cigarette lighter adapter that came with mine didn't provide enough current to offset the draw so I often found if I used it to get to the airport my iPaq was dead for flying and had to be recharged. Recently my iPaq went legs up so I replaced it with an iPaq 5550 with build in Bluetooth. I did some research and got a latest generation bluetooth GPS - the GlobalSat BT GPS Receiver BT-338 - it's $179 - about $40 more than the Navman. It's based on the SiRF III chipset which keeps a database of expected satellite locations so it picks up a fix from a cold start in about 15 seconds -- it's ready before I can get the nav software booted. It runs on it's own internal battery for something like 15 hours (!) Not sure how long the iPaq runs just on its own battery with the backlight on and Bluetooth active, but I think it's a few hours. I have used it with SeeYou mobile and it works flawlessly (not tried it with WinPilot yet). For auto navigation I got a copy of CoPilot 5 for $99 (normally $250 or so) by trading in my Navman software. It too is a big improvement though I am still working through some installation issues. I picked CoPilot in large part because it is the only auto navigation software I looked at that will navigate to a LAT/LONG position - nice for retrieves. Of course you need an iPaq with Bluetooth to use it, so a drop out the vent window might be in order. Depends on if you want to pony up $600-700. Maybe there's a bluetooth module for the SD slot on your iPaq. 9B |
I can second Andy's negative experiance, especially the TTFF (Time to First
Fix). Imagine waiting 15 minutes to get the satellites. During that time you think that something is wrong with the settings/Ipaq etc. and if you play around with them you even have to wait longer. I was using it with WinPilot when I am flying in glider with no GPS equiped. Navman is so slow that often the information from WinPilot is just plain wrong. Also the connection with the suction cup is a joke. I had to manually adjust the plastik with tape that a proper connection was made. The suction cup by itself is also not good because it often happens during the flight that it gives up. All in all I would not recommend it!! Look out for alternatives like the already mentioned ones. Christian |
"Doug Snyder" wrote:
There are other options for use with a PDA but none I've found for use with the 3700 series. IMHO there are two solutions. Get a double slot CF expansion jacket (use one slot for a CF GPS receiver and the other for a memory card). Or get a bluetooth+CF expansion jacket and a bluettoth GPS receiver. I have the latter setup, works very well with various programs. Both solutions don't require any wiring setup (always fault prone). In flight, I just connect the Ipaq to my logger's NMEA output, which feeds data to the flight computer, also. ciao Aldo Cernezzi |
I've been using an iPAQ 3850 for both Flight Computer and Car Navigation. I
use a PCMCIA jacket and CF GPS unit. The jacket provides additional battery power. Since I currently only fly club ships, I don't connect the iPAQ to the 12v power in the plane. I get 3+ hours of continually on time. I don't how long it will last as I have never run out of battery. I use a RAM mount with suction cup for the iPAQ in the plane - again it has held on the canopy for 3+ hours. I use another RAM mount in the Car, this time with a ball fastened to the dash. It holds the iPAQ near the steering wheel where it is easy to glance at it. I had been using a Teletype that I purchased a number of years ago. It worked okay, but it's TTFF was not great. I recently purchased a Haicom 303MMF which uses a SiRF chipset and has an internal battery to retain last position information. On a cold start the TTFF appears to always be less than a minute. I use GPS_Log for flight software. I'm looking at SeeYou Mobile. GPS_LOG has worked with both receivers. On the 3850, the received shows up as COM5. The specific COM port varies by iPAQ model. After giving up on Delorme Street Atlas for Car Navigation. The Teletype originally came with World Navigator. I didn't care for it much. The newer version looks muc improved, but it will only work with Teletype GPS receiveers. I looked at Tom-Tom, but they also warn about not being reliable with CF GPS receivers. I chose iGuidance from iNAV. So far, I've been pleased with it. If you go off route, it immediately calculates a new route and only requests a U-Turn if there is no alternative. It has a 3-D display mode. It allows you to insert a destination in Lat/Long easily and immediately plots a route from the current location (other alternatives available). Ease of use with respect to plotting a route to a Lat/Long was important, since the primary purpose will be for my wife to quickly get a route to come find me when I land out. John Scott |
| NAVMAN GPS | Mike Hostage | Soaring | 8 | May 25th 05 12:50 PM |
| NAVMAN GPS | [email protected] | Soaring | 0 | April 7th 05 10:19 PM |
| Navman PiN Pocket PC for glider usage | [email protected] | Soaring | 1 | February 8th 05 01:17 AM |
| Question about GNII | Joseph L. Hyde | Soaring | 5 | December 20th 04 07:10 PM |
