A friend just had the axle break on his Eberle trailer. Any thoughts on an easy swap? Or should he rent a flatbed to get it home then take his time to replace it?
He's about 50 miles inside Virginia on I-81 on his way to the DC area. 5Z |
A roadside axle swap is probably not an option, since you will not likely find a direct replacement. Even if the axle can be repaired on site (welded or patched together somehow) the trailer will probably have to be jacked up, the axle removed, repaired and then reinstalled by someone with the right portable equipment.
Rent the flatbed and get it home. Don't risk the trailer, the glider and possibly your car (and your life!) trying to tow a compromised trailer. And if it breaks free while trying to tow it, you are also putting other motorists at risk. And sending up a big red flag for the circling personal injury lawyers. |
On Wednesday, November 11, 2020 at 10:15:57 PM UTC-5, wrote:
A roadside axle swap is probably not an option, since you will not likely find a direct replacement. Even if the axle can be repaired on site (welded or patched together somehow) the trailer will probably have to be jacked up, the axle removed, repaired and then reinstalled by someone with the right portable equipment. Rent the flatbed and get it home. Don't risk the trailer, the glider and possibly your car (and your life!) trying to tow a compromised trailer. And if it breaks free while trying to tow it, you are also putting other motorists at risk. And sending up a big red flag for the circling personal injury lawyers. What Mark said. Then find out what brand the original axle is and find the US distributor for it. We are currently going through that exercise after the axle of our TwiAstir got damaged. It is a 1 to 1 drop-in replacement and is on the way from the Fatherland. Uli 'AS' |
17M Eberle Trailer | Phil Chidekel | Soaring | 0 | July 28th 19 02:18 PM |
Need a new axle for my eberle trailer .... | Peter Deane[_2_] | Soaring | 10 | July 23rd 18 01:56 PM |
Looking for an Eberle trailer door | SoaringXCellence | Soaring | 4 | August 11th 16 05:08 AM |
weight of an Eberle trailer | raymond herr | Soaring | 3 | November 27th 11 06:20 PM |
Eberle trailer wheel rims | Bob | Soaring | 7 | November 25th 11 05:39 PM |
