weight of an Eberle trailer
Old November 25th 11, 05:50 PM
raymond herr raymond herr is offline
Junior Member
First recorded activity by AviationBanter: Nov 2011
Default weight of an Eberle trailer
Just wondering if anyone has a good estimate on the empty weight of an Eberle clamshell trailer (Labelle).
ray
Old November 26th 11, 01:19 PM posted to rec.aviation.soaring
GM
On Nov 25, 12:50*pm, raymond herr raymond.herr.
ray
raymond herr
Hello Ray,
if it is an original Eberle trailer, there should be a stainless steel
tag somewhere on the frame calling out the empty and max gross weight
in kg. Multiply by 2.2 to get lbs.
Uli
Old November 27th 11, 06:01 PM posted to rec.aviation.soaring
Hans Disma
According the factorybrochure the empty weight was 925 lbs
Hans Disma
"raymond herr" schreef in bericht
ray
raymond herr
Old November 27th 11, 06:20 PM posted to rec.aviation.soaring
glidergeek
On Nov 25, 9:50*am, raymond herr raymond.herr.
ray
raymond herr
Max wt for the axle is 1000kg or 2200 lbs, as I recall my old Standard
Cirrus weighed about 500 lbs empty. That trailer should be about 1200
lbs. without gear with spare tire.
Eberle trailer wheel rims Bob Soaring 7 November 25th 11 05:39 PM
Typical glider & trailer total weight? Roger Worden[_2_] Soaring 9 February 8th 10 02:24 AM
Trailer Weight rlovinggood Soaring 8 November 1st 07 12:22 AM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Eberle Surge Brake Rebuild Jim Hendrix Soaring 0 June 18th 04 08:28 PM
