Vc gear difficulty
Old April 5th 21, 12:49 PM posted to rec.aviation.soaring
Phoenix
Default Vc gear difficulty
Anyone have a solution as to why my gear is so VERY difficult to retract / extend on my Ventus c? It's the very last 10% trying to get the lever into the indent that's the problem.
Old April 5th 21, 02:51 PM posted to rec.aviation.soaring
Tim Taylor
1. Check and lube all the sliding tube and linkages.
2. Check that the cotter pin is installed correctly on the end of the axel. It should not have sharp edges exposed. This can bind on the gear door. Signs of wear or scratching on the door are an indication of a problem. I have installed UHMW slides on the doors to help with this.
3. Have a mechanic that is familiar with S-H gliders adjust the gear mechanism.
4. Adjust your padding in the cockpit to make sure you can reach both ends of the gear swing with enough force to swing the gear.
Old April 5th 21, 03:07 PM posted to rec.aviation.soaring
Phoenix
Thanks for the tips, Tim. By the way, what is "UHMW"?
Old April 5th 21, 03:21 PM posted to rec.aviation.soaring
2. Check that the cotter pin is installed correctly on the end of the axel. It should not have sharp edges exposed. This can bind on the gear door.. Signs of wear or scratching on the door are an indication of a problem. I have installed UHMW slides on the doors to help with this.
Ultra high molecular weight.....usually a milky white slippery plastic/polyethylene. Sometimes found in the bottom of a spar box to allow sliding the wing spars in easier and resisting wear.
Old April 6th 21, 07:51 AM posted to rec.aviation.soaring
bumper[_4_]
To add to Charlie M's response:
UHMW-PE, the PE is polyethylene. It is next to Teflon in low friction and as tough as steel in some applications. 1" thick will stop a 45 ACP round. Besides sheets and assorted shapes, it's also available in tape (various thicknesses and widths - try Amazon). Because of it's mechanical strength, you can't stretch the tape by any significant degree to make turns or to follow compound curves. The 10 mil (0.010") thick tape won't fold over an edge neatly, but 4 to 6 mil will do edges ok. Very handy to have to "overhaul a low speed sleeve bearing shaft to take out play - - lots of uses around the shop.) Get the 10 mil for your gear doors.
bumper
Old April 6th 21, 08:18 PM posted to rec.aviation.soaring
Frank Whiteley
bumper
It's also modern glider winch rope known as spectra and dyneema 75 and their variants.
Frank
Old April 5th 21, 03:46 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Also check that the bolts and nuts for the gear are not too tight and are well lubricated. This may happen if the gear has be removed and reinstalled.. If you continues to pull/Push on an overly tight gear handle good chance that the handle may break off.
How do I know this????
Richard
www.craggyaero.com
Old April 5th 21, 03:54 PM posted to rec.aviation.soaring
Phoenix
Also check that the bolts and nuts for the gear are not too tight and are well lubricated. This may happen if the gear has be removed and reinstalled. If you continues to pull/Push on an overly tight gear handle good chance that the handle may break off.
Richard
www.craggyaero.com
Thank you Richard. This strikes a chord as the gear mech. has been reinstalled by a previous owner. I'll definitely check these as I've definitely felt that I may break off the handle!
Old April 5th 21, 05:07 PM posted to rec.aviation.soaring
John Sinclair[_5_]
Richard
www.craggyaero.com
Don’t neglect to lube the gear door hinges, I’ve seen them so stiff that it’s hard to move by hand! Also, check the new tire To verify its the brand and style called out in the manual.......not all tire styles will fit into your wheel well (round face, not squared off)
It’s very hard to get to all the lube points with the fuselage upright, if possible, remove the canopy and lift the fuselage up onto saw-horses. Then roll it 90 degrees left and then right in order to clean, lube and inspect all moving parts! Move the gear up and down while observing the wheel well and doors............problem should become obvious. Many gears have springs that assist in lifting the gear.....check for broken/missing springs?
Good luck,
JJ
Old April 5th 21, 05:51 PM posted to rec.aviation.soaring
John Galloway[_2_]
Richard
www.craggyaero.com
Good luck,
JJ
I have found with several SH gliders that apart from the heaviness of lifting the gear there are 2 other issues. Firstly if you pull the handle too fast it bounces forward off the back stop so won't go in the detent. Secondly, when the handle is held in the natural thumb up position the thickness of the knuckles stops the handle from being held vertically enough to get fully into the detent. I invert my grip, which keeps the handle closer to the wall, and I try to retract smoothly while pushing the handle towards the cockpit wall.
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 November 12th 18 01:49 PM
ASW 28 Service Difficulty Report Andy[_1_] Soaring 2 May 4th 11 07:40 PM
Difficulty in posting to r.a.s. delboy Soaring 7 November 7th 09 08:15 PM
iPAQ Touchscreen Difficulty jcarlyle Soaring 6 August 20th 09 02:34 AM
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:50 PM
