ASW 28 Service Difficulty Report
Old May 4th 11, 06:08 PM posted to rec.aviation.soaring
Andy[_1_]
Default ASW 28 Service Difficulty Report
While preparing ASW 28 serial 28048 for annual inspection I noticed
wear on the brake caliper. The aft, upper, outer corner of the
caliper had a bright wear mark and a significant amount of the caliper
corner had been worn away. The was also wear on the upper caliper
bolt head and the safety wire that secures the caliper bolts had been
worn through. I found that when the gear was in the retracted position
the flexible brake pipe was in contact with the corner of the caliper.
When the gear was retracted or extended the steel braid of the brake
line was rubbing on the softer caliper and wearing it away. There was
no visible damage to the brake line. My temporary solution was to
wrap the brake line in a plastic spiral wrapping as used to contain
electrical cable harness or looms.
I inspected two other ASW 28 at my club. One with a slightly later
serial than mine showed caliper wear, another earlier serial number
had no wear. Two ASW 27 were also checked and neither showed any
caliper wear.
I suggest that all ASW 28 owners should check for this problem. If
uncorrected it could wear the caliper to the point that it would
require replacement. It seems possible that it could also cause a
failure of the brake line.
Andy
Old May 4th 11, 07:28 PM posted to rec.aviation.soaring
[email protected][_2_]
wear on the brake caliper. *The aft, upper, outer corner of the
corner had been worn away. * The was also wear on the upper caliper
line was rubbing on the softer caliper and wearing it away. *There was
no visible damage to the brake line. *My temporary solution was to
I inspected two other ASW 28 at my club. *One with a slightly later
had no wear. *Two ASW 27 were also checked and neither showed any
caliper wear.
I suggest that all ASW 28 owners should check for this problem. *If
Andy
You should contact the Factory, there may already be a S/B that talks
to this. If not, I am sure they would like to know about it.
aerodyne
Old May 4th 11, 07:40 PM posted to rec.aviation.soaring
Andy[_1_]
On May 4, 11:28*am, "
caliper wear.
Andy
aerodyne- Hide quoted text -
- Show quoted text -
Yes, I have done that, and also copied the US agent.
Andy
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 10:17 PM
Difficulty in posting to r.a.s. delboy Soaring 7 November 7th 09 08:15 PM
iPAQ Touchscreen Difficulty jcarlyle Soaring 6 August 20th 09 02:34 AM
US, Retrieve Cell service getting worse, Analog service disappearing. chris Soaring 10 December 24th 07 11:50 PM
Service Bulletins, Service Letters, Service Spares Letters O. Sami Saydjari Owning 5 December 26th 03 05:36 AM
