![]() Have you ever "made up" an approach to a nonexistent airport for the purposes of training or currency? I mean, to pick a space in the boonies, and then use nearby navaids to fashion a homemade approach to an imaginary runway. Some instructors will do this. Now, I was wondering, is there any way flying such an "approach" could be loggable towards instrument currency? (obviously, under the hood, VFR, with a safety pilot. You'd be insane and illegal to try this with real IMC) The advantages this could provide are mostly convenience (not having to deal with the traffic-related delays associated with an approach to a real airport with real controllers) and also variety -- you could fly flavors of approaches that aren't available near where you live. What do you guys thing? -- dave j 61.57(c)(1): (c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has: (1) For the purpose of obtaining instrument experience in an aircraft (other than a glider), performed and logged under actual or simulated instrument conditions, either in flight in the appropriate category of aircraft for the instrument privileges sought or in a flight simulator or flight training device that is representative of the aircraft category for the instrument privileges sought- (i) At least six instrument approaches; (ii) Holding procedures; and (iii) Intercepting and tracking courses through the use of navigation systems. |
Only got nine hits when I searched my Summit Aviation CD of all FAA pubs,
and every hit implied a published approach. I doubt that the regulations writers ever contemplated that someone would consider an unpublished approach to have any legal standing. How would you comply with 61.51(g), which requires that the location and type of each approach be logged? Logging "PAE ILS 16" looks a lot better than "Podunk VOR approach" when Podunk doesn't have any approaches at all. If these home-made approaches were based on a navaid that is a part of a published approach, I would be concerned about IFR traffic using the same airspace...although "out in the boonies" makes that unlikely. IOW, I do not consider the practice to be practical. Bob Gardner wrote in message oups.com... Have you ever "made up" an approach to a nonexistent airport for the purposes of training or currency? I mean, to pick a space in the boonies, and then use nearby navaids to fashion a homemade approach to an imaginary runway. Some instructors will do this. Now, I was wondering, is there any way flying such an "approach" could be loggable towards instrument currency? (obviously, under the hood, VFR, with a safety pilot. You'd be insane and illegal to try this with real IMC) The advantages this could provide are mostly convenience (not having to deal with the traffic-related delays associated with an approach to a real airport with real controllers) and also variety -- you could fly flavors of approaches that aren't available near where you live. What do you guys thing? -- dave j 61.57(c)(1): (c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has: (1) For the purpose of obtaining instrument experience in an aircraft (other than a glider), performed and logged under actual or simulated instrument conditions, either in flight in the appropriate category of aircraft for the instrument privileges sought or in a flight simulator or flight training device that is representative of the aircraft category for the instrument privileges sought- (i) At least six instrument approaches; (ii) Holding procedures; and (iii) Intercepting and tracking courses through the use of navigation systems. |
![]() Thanks Bob and Roy, this is what I figured, but it was worth a try. I assume that this also applies to airways and holds, then. That is, real victor airways and real holds (which I guess would be holds published on charts or approach plates, or designed and assigned on the fly by a real controller.) -- dave j |
![]() Ooh, I'm going to follow up my own post. Obviously, intercepting courses does not mean V airways, so anywhere you're going is fine as long as you use a "navigation system." And holding procedures is probably the same. -- dave j |
Ross Oliver wrote:
The disadvantage is you must use a CFI, not just a safety pilot. I believe you may also use an IGI (instrument ground instructor) in a sim in lieu of a CFI. CFI's cost more ! Antonio |
![]() "dancingstarcreations" wrote in message ... I believe you may also use an IGI (instrument ground instructor) in a sim in lieu of a CFI. CFI's cost more ! So IGI's make...oh what, about $2.00 an hour? |
dancingstarcreations wrote
in : Ross Oliver wrote: I believe you may also use an IGI (instrument ground instructor) in a sim in lieu of a CFI. CFI's cost more ! Not true. I'm both IGI and CFII. Currency or other required training, if done in a sim, requires the CFII endorsement. IGI won't do it. |
182RG question | Paul Anton | Owning | 11 | May 16th 05 09:45 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
