182RG question
Old May 12th 05, 03:30 AM
Paul Anton
Default 182RG question
I am hoping to tap some of the expertise here to solve a problem I have run
into.
I am a retired guy who was called by a local Part 141 school to fill in as
their flightline mechanic until they could find a permanent A&P. They have
an early 182RG (serial 141) that has an ongoing electrical problem.
My first question concerns the ammeter. I have definitely confirmed that the
ammeter is defective. It appears like the ENTIRE gage cluster will have to
be replaced. The parts manual shows that the original gage is not available.
A supersession was listed which also consisted of a single gage. However
when this was pursued it was not available as a single replacement.
So my question is has anyone come up with a solution for a single defective
gage in this cluster that does not involve replacing the entire thing? How
about an instrument shop that would rebuild the ammeter? I have been unable
to find an instrument shop that would bother with an ammeter.
Here's my second question. I think the reason the ammeter broke is that it
simply wore out. The voltage and hence the current is constantly varying.
The original ammeter needle was oscillating so much that you couldn't tell
if the system was charging or not. I put a test ammeter in series and the
although the ammeter could be read, it was still oscillating. A check with
an analog meter showed fluctuations that increased in frequency as the RPM
was increased. Ditto for increasing the load. A scope shows about 900 mv
peak.
Persons before me have replaced the alternator and regulator. (a note here,
the regulator is the simple 3 wire unit)
All grounds were cleaned and remade.
Any hints of where I should begin my search would be greatly appreciated. I
have to pull this beast out of the hanger to run it up. With out Northwest
weather I haven't had two clear days to work on it outside and I'm too old
and stiff to do a lot under the panel. So any hints or experience of a
similar trouble would really be appreciated.
I'm going to jumper the alternator field portion of the dual master switch
to start with but beyond that ----------------
Thanks in advance
Paul Anton
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 10:40 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 01:14 AM
