I am considering purchasing a Canadian built and registered Searey
homebuilt. What do I have to do to get an N-number on it? thanks, ted |
On Sat, 11 Jun 2005, ted wrote:
I am considering purchasing a Canadian built and registered Searey homebuilt. What do I have to do to get an N-number on it? You'll want to call your local FSDO, and also AOPA & EAA, assuming you're a member. Basically, it needs to be deregistered in Canada, then FAA will come look at it, and register it. You'll also need to consider how to get it across the border. If you fly it across, the paperwork gets pretty complicated, because you're a US pilot flying a Canadian aircraft that you don't own. (You can't complete the sale until it's here, or else it won't be registered, and you can't fly it home.) There's a (probably very slim) chance of severe penalties up to and including confiscation of the aircraft, if you don't have all the appropriate ducks in a row. It's a lot simpler to have the seller fly it to you. -Dan |
On 11 Jun 2005 19:02:01 -0700, "ted" wrote:
I am considering purchasing a Canadian built and registered Searey homebuilt. What do I have to do to get an N-number on it? thanks, ted Is the plane registered as homebuilt or advanced ultralight? If homebuilt it should be relatively easy - if advanced ultralight it may be more difficult - as it has (almost certainly) ALREADY been de-registered in Canada due to a fiasco with registered vs actual weights. |
I just purchased a Canadian registered Velocity. What I would suggest
is that you have the current owner fly the plane to the US (a non-event for them). If the current owner is shrewd, he/she will not be willing to de-register until you purchase the plane outright (because re-registering is a big hassle in Canada). That puts you at risk because you've then purchased a plane that is un-airworthy (since is not registered here, which it can't be until it is de-registered in Canada). The way around this is to come to an agreement with your DAR. Pay him to do the inspection / registration in two parts. A pre-registration inspection will assure you that the plane is indeed airworthy in the eyes of the FAA (or their designate in this case). Once the DAR he has confirmed it is airworthy and he/she will certify it, the owner can de-register in Canada (which only takes a few days). Then all you have to do is plaster with N-number and experimental stickers and fly away. If you need a loan, it get's quite a bit more complicated but can be done (I did it and both buyer and seller were pretty well protected). Jeff ted wrote: I am considering purchasing a Canadian built and registered Searey homebuilt. What do I have to do to get an N-number on it? thanks, ted |
Pitts Number 1 registration number | Mirco | Aerobatics | 3 | December 4th 04 11:50 AM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
p3/95 | [email protected] | Military Aviation | 1 | September 27th 04 12:27 AM |
Canadian registration to US? | CFLav8r | Owning | 7 | March 15th 04 03:35 AM |
