p3/95
Old September 27th 04, 01:21 AM
Default p3/95
Subject: P-3C Ditches with Four Engines Out, All Survive!
Date: Wed, 22 Sep 2004 18:07:54 +0930
"Scet"
Newsgroups: rec.aviation.military
With all the non - aviation military posts on this group, I thought I'd
post
this article. There maybe a few in this group that are actually
interested
in Military aviation! Some of you may have read this before. The article
appeared in Foundation Volume 18 Number 1 - Spring 1997
Scet
"They Said It Would Never Happen:"
"A P-3C Ditches with Four Engines Out, All Survive!"
25 March 1995
While going through the P3 FRS, newly winged aviators have always asked
question: "Has a P-3 ever lost all four engines at the same time." The
answer was always: "No, it will never happen." Well as Murphy's Law
applies,
it can - and we did.
While on deployment and after performing an anti-submarine warfare
mission
with the USS Constellation (CV-64) battle group, which was located 200
miles
east of Oman, VP-47 combat aircrew nine was returning to Masirah, Oman.
The
flight station crew was composed of LCDR Mark Radice, a lieutenant
commander
and a former P-3 FRS instructor who had just checked into the squadron
19
days earlier for his second tour; AE 1 Richard White, the flight
engineer;
and me, a senior lieutenant in the squadron with about 273 aircraft
commander hours.
Little did we know that we were about to experience the beginning of
what
would eventually be one of the worst P-3 mishap ever. We had just
restarted
the number one engine, which was loitered on station to conserve fuel,
and
climbed up to an altitude of 16,000 feet for our transit home. At about
130
miles east of the island of Masirah, Oman, the flight engineer noticed
that
the number one prop pump warning light on the number four engine was
illuminated. I directed the flight engineer to increase the number four
power lever, which was the first step of our emergency procedure, and it
also ensured that we have a good blade angle.
We then pulled out our NATOPS flight manual commonly referred to as the
"Big
Blue Sleeping Pill," and read through the remaining steps of our
procedure.
Having a prop pump light in itself was not a big worry, but it could
eventually lead to bigger problems. Approaching 80 miles east of
Masirah,
the situation worsened. The second prop pump light on the number four
engine
illuminated and the prop began to overspeed. The crew went through the
overspeed procedures, and we determined that the prop was pitch locked.
This
malfunction does not occur on a regular basis in the P-3 Orion, so
needless
to say, the flight crew's concern and heart rate increased as to what
would
happen to the prop when we fuel chopped the engine during our descent to
land.
We flew back to the airfield at 16,000 feet and executed a slow,
spiraling
descent to maintain our number four engines rpm at 100 percent. Not
knowing
what would happen when we fuel chopped the number four engine, the
flight
station went through the descent, approach and three engine landing
considerations checklists. Approaching 6,000 feet and nearing the
engine's
limit power setting, we decided to circle the field one last time,
extend
out fora good downwind leg and fuel chop the engine in anticipation for
our
landing. Unfortunately, we would not get to land at the airfield.
Passing
5,600 feet, we heard and felt a tremendous explosion. My co-pilot, who
was
in the right seat, looked out and saw a huge cloud of black smoke. To
his
utter dismay, when the smoke cleared, he saw the number four prop
missing
and the reduction gear box on fire. LCDR Radice called out to shut down
number four engine and discharge the fire extinguisher.
I was in the left seat, so I was unable to see what was going on.
Trusting
his judgment, I concurred with the decision to shut the engine down. The
flight engineer shut down the engine and discharged the fire
extinguisher.
LCDR Radice looked out at the engine and the fire was still raging. AE1
White then discharged the second fire bottle. Unfortunately, the fire
kept
burning. AE 1 White then called out that the number three engine's rpm
was
winding down. LCDR Radice looked out at the number three prop and called
out
that the prop are looked bad. It made sense that during the explosion,
number four engine probably took out the number three engine. We then
called
out to shut down the number three engine. While the flight engineer was
pulling the number three emergency shutdown handle, I simultaneously
advanced the number one and number two engine power levers.
Expecting to hear or feel a pitch change in the prop and not getting
one,
you can imagine my reaction when I looked out and saw both props barely
rotating. Upon seeing this, I looked back inside the flight station to
let
the rest of the crew in on the secret, but AE 1 White beat me to it and
called flameout on number one and two engines.
All of the sudden the flight station went dark due to a total electrical
power loss. Shaking my head with dismay, "saying you've got to be
kidding
me," we directed AEI White to pull the hydraulic boost handles and start
auxiliary power unit in order to get electrical power back. At this time
we
were gust locked, which is the same as when your car's steering column
locks
up and you can't move it. To say the least, it was not a good feeling.
After
the boost handles were pulled, the flight engineer made several attempts
to
start the APU, but it kept flaming out. At this point things were really
looking bad for VP-47's crew. When the boost handles were pulled, the
aircraft should have switched from a hydraulic to a mechanical
advantage.
For some reason, this didn't occur and we were unable to control the
aircraft. The aircraft rolled right into a 45-50 degree angle of bank
and
our airspeed bled off from 260 to 210 knots.
On the flight station we thought that the aircraft was going to stall
and
roll inverted. What a horrible gut wrenching feeling it was to think
that
this was going to be the end for everyone. I was their aircraft
commander
and I as responsible for their well-being. I could not get control of
aircraft and we did not have time to put on our parachutes to bailout.
Even
if we would have had time to don our parachutes, the main cabin door was
facing the sky, which made bailing out impossible.
Up to this point, the entire evolution from engine explosion had taken
about
45 seconds. With my heart pounding from being afraid and wanting to save
rest of the crew, I said a quick prayer. My prayers were answered. The
control column went boost out and unlocked. Finally at about 2,500 feet,
we
were able to control the aircraft. We leveled the wings, then continued
in a
left hand turn to acquire the airfield. When I saw the airfield 90
degrees
off of our left wing, we were at 2,000 feet and 6-7 miles away from
land. A
harsh reality set in -- we were going to have to ditch the aircraft.
Having never heard of or seen NATOPS procedures for a no engine,
no-flap,
boost-out ditch, the we had to use gut instinct. We knew that if we flew
too
fast, it would be hard to pull the nose up upon water entry. If we flew
to
slow, the aircraft would stall soon after leveling off above the water.
We
maintained our airspeed between 175-180 knots, which gave us a 1,000 fpm
rate of descent. At this time, as with all life threatening situations,
each
crew 7 member's adrenaline system kicked in to its maximum. Fortunately,
I
had a great set of parents and a high school football coach who was a
former
Oakland Raider all-pro football player who taught me to never quit and
find
ways to win. At about 1,200 feet, we told the rest of the crew to
prepare
for immediate ditching. At 200 feet approaching water entry, both LCDR
Radice and I started pulling back on the yoke. The nose came up nicely.
The
two biggest items necessary to perform a successful ditch is to maintain
wings level and have a shallow rate of descent. At first, we were able
to
keep our wings level and get our rate of descent to about 300 feet per
minute. At 80 feet, the right wing started rolling as we slowed down.
LCDR
Radice recognized the problem, called for left full yoke and the right
wing
came back up. Upon water entry, we were wings level, had a 200 feet per
minute rate of descent and were right at 135 knots. After several skips
across the water and fighting to keep the nose of the aircraft up, the
plane
finally came to rest. A P-3 ditch can best be described as being similar
to
a log ride at an amusement park, but with more of a kick in the pants.
The amazement of still being alive with the Orion still afloat caught me
off
guard, but there was little time for celebration. The water traversed
through the tube of the aircraft and shot into the flight station like
someone pointing a fire hose at us. My co-pi lot and flight engineer
evacuated the aircraft through the overhead escape hatch. I evacuated
aircraft through the side escape hatch located immediately behind the
pilot
seat on the left side. After jumping into the water, I soon realized
that
the plane was still drifting like a boat does without power.
To my chagrin, the number two prop was coming right for me and was going
to
plow right over me. All that 1 could do was to paddle backwards as fast
as I
could to avoid the prop, putting my hands on the prop to push me out of
its
way. Fortunately, the aircraft came to a stop and I was able to swim to
leading edge of the wing between the number one and number two engines.
I
called out to LCDR Radice to see if the whole crew made it out of the
aircraft. I was covered from head to toe with aircraft fuel and my eyes
were
on fire. My flight gloves were slippery from the fuel and this made it
difficult to climb on top of the wing. After three tries, I was finally
able
to climb on top of the wing and reach the my TACCO and in-flight
technician.
The rest of the crew evacuated out the starboard side escape hatch and
entered their life rafts. My in-flight tech nician was pulling the ring
to
inflate the life raft, but the blasted thing would not inflate.A pilot
friend of mine and his crew were waiting to take off to pick up an
admiral
in Bahrain when we hit the water. Shortly after we got into the life
rafts,
my buddy flew over and the crew let out a big yell. Once things finally
settled down, the crew looked each other over and checked for injuries.
To
my surprise, not a single crew member was injured. The only person with
a
problem was me.
Up to this point I had controlled my temper quite well, but this was too
much. After a few choice words directed to the life raft, the only
option
left was to inflate our life vests and swim around to the other side.
Realizing our predicament, the crew in the other life rafts began to
paddle
around the rear of the aircraft in order to meet us. The three of us
joined
the other crew members and climbed into the rafts.
I had fuel in my eyes and they were burning like crazy. My sensor one
operator carried a little water bottle in his life vest. He pulled out
water bottle and began to pour it in my eyes to flush out the fuel.
While he
was taking care of me, my TACCO and second pilot were trying to contact
other P-3 crew on our PRC-90 radios to let them know of our status.
This day was true to form, because my TACCO went through three radios
before
he found one that worked. On the fourth radio, he was finally able to
talk
to the other crew to let them know that we were fine.
We were in the rafts for only 10 minutes before the SAR helicopter
arrived.
The rescue was uneventful. The helicopter took seven crew members on the
first trip and four crew members on the second trip.
A month later, a barge and crane raised the aircraft and we discovered
that
the number four prop had thrown a blade. The imbalance of only three
blades
caused the engine to explode. The prop blade was thrown from right to
left
and cut through the body of the aircraft, severing 35 of 44 engine and
flight control cables. Four of the cables cut went to the four engines.
The
cutting action caused a pulling action which shut down all four engine
simultaneously. The hydraulic boost handle cables were cut and the APU
fuel
line was cut. The nine intact cables were two aileron cables, two
elevator
cables, two elevator trim tab cables and two rudder trim tab cables.The
co-pilot's main flight control cable was cut. VP-47's crew nine flew
under a
lucky cloud that day.
For so many things to So wrong and everything to work out perfectly was
a
total surprise to me. I have never questioned the reason we were spared,
but
I am glad that we were.
