I am working on the planning for a 1000K attempt. One question I have
is how much water should I launch with in my Ventus B? I can carry up to 40 gallons (150 liters), but for a 1000K flight I will need to launch in early weak conditions, followed by strong conditions latter in the day. Options would be to launch with 20 to 40 gallons. Twenty to thirty would probably give a good balance for early climb and later running. Any suggestions for an optimum balance? Thanks, Tim |
At 04:54 01 August 2005, Ttaylor At Cc.Usu.Edu wrote:
I am working on the planning for a 1000K attempt. One question I have is how much water should I launch with in my Ventus B? I can carry up to 40 gallons (150 liters), but for a 1000K flight I will need to launch in early weak conditions, followed by strong conditions latter in the day. Options would be to launch with 20 to 40 gallons. Twenty to thirty would probably give a good balance for early climb and later running. Any suggestions for an optimum balance? The optimal, assuming strong enough conditions to support 1000k, is full water - so long as you can stay aloft early in the day. The slower climb in the first 1-2 hours of the day is more than offset by the faster cruise for the peak 6-7 hours later on. 9B |
Andy Blackburn wrote:
At 04:54 01 August 2005, Ttaylor At Cc.Usu.Edu wrote: I am working on the planning for a 1000K attempt. One question I have is how much water should I launch with in my Ventus B? I can carry up to 40 gallons (150 liters), but for a 1000K flight I will need to launch in early weak conditions, followed by strong conditions latter in the day. Options would be to launch with 20 to 40 gallons. Twenty to thirty would probably give a good balance for early climb and later running. Any suggestions for an optimum balance? The optimal, assuming strong enough conditions to support 1000k, is full water - so long as you can stay aloft early in the day. The slower climb in the first 1-2 hours of the day is more than offset by the faster cruise for the peak 6-7 hours later on. Take off full, dump until you can stay up, just like at a contest. If you can stay up easily when full, you are either flying in a great place, or you took off too late! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Fill it to the top go early get high go fast and get home.
![]() "Andy Blackburn" wrote in message ... At 04:54 01 August 2005, Ttaylor At Cc.Usu.Edu wrote: I am working on the planning for a 1000K attempt. One question I have is how much water should I launch with in my Ventus B? I can carry up to 40 gallons (150 liters), but for a 1000K flight I will need to launch in early weak conditions, followed by strong conditions latter in the day. Options would be to launch with 20 to 40 gallons. Twenty to thirty would probably give a good balance for early climb and later running. Any suggestions for an optimum balance? The optimal, assuming strong enough conditions to support 1000k, is full water - so long as you can stay aloft early in the day. The slower climb in the first 1-2 hours of the day is more than offset by the faster cruise for the peak 6-7 hours later on. 9B Don't forget to have a plan for dumping the water. There's no need to hold on to it after the thermal strength drops below that which justifies ballast. It probably won't get any better late in the day. This is particularly true if you have a tailwind on the final leg. Bill Daniels |
There is no substitute for wing loading!
ttaylor at cc.usu.edu wrote: I am working on the planning for a 1000K attempt. One question I have is how much water should I launch with in my Ventus B? I can carry up to 40 gallons (150 liters), but for a 1000K flight I will need to launch in early weak conditions, followed by strong conditions latter in the day. Options would be to launch with 20 to 40 gallons. Twenty to thirty would probably give a good balance for early climb and later running. Any suggestions for an optimum balance? Thanks, Tim |
My two longest flights ever -- 970 and 930 km -- were at the highest
wing loading I could get. If you're doing a flight as long as 1000km, you're going to be spending the vast majority if your time (at least 70%, more likely 80% or 85%) on course, not turning in lift. So top of the tanks, get high, and have fun!!! -tuno |
Full water and wait for launch until you can stay up with full water.
The majority of the day will be strong conditions - you need the water then more than you need an early launch. Wait until it is "cooking". I have flown 23 flights of 1000 km + at Bitterwasser, Namibia (Africa). |
At 18:48 02 August 2005, Eric Greenwell wrote:
Tactically, one should take off with full ballast early enough to have a chance of completing the flight, and drop whatever it takes to stay up. That's one approach - but keep in mind that the difference in climb rate between full and empty (in a 45-degree bank) is less than 50 fpm. Furthermore, the McCready-derived XC speed differential for full versus empty water is 6-9 knots. The actual difference with streeting, etc. may be greater. That amounts to about an hour less time on course with water versus without. To break even without ballast you'd have to make about 80 miles before you could get started on course with ballast. I'm thinking this would only be true if the day developed with either very weak (0.5-1.5 knots climb, dry) or very narrow thermals for a very long time (1-2 hours). Under those conditions I don't think you're making 80 miles even if you have Helium in your wings. I'd recommend taking tows until you can stay up with full water. 9B |
Airbus A380 water purification | john smith | Piloting | 1 | July 7th 05 02:50 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Water, water, everywhere, but none for thirsty wings.... | Chris OCallaghan | Soaring | 0 | November 21st 04 03:14 PM |
Questions regarding Air/Oil Separators | Doodybutch | Owning | 6 | April 20th 04 05:56 PM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
