When you remove fabric from a tube fuselage, the part that is glued
down will be like concrete. I know I dare not scrape for fear of scratching the tubing. How do you soften/remove the remaining fabric and glue residue? - Mike |
MEK?
Scott Michael Horowitz wrote: When you remove fabric from a tube fuselage, the part that is glued down will be like concrete. I know I dare not scrape for fear of scratching the tubing. How do you soften/remove the remaining fabric and glue residue? - Mike |
"Michael Horowitz" wrote in message ... When you remove fabric from a tube fuselage, the part that is glued down will be like concrete. I know I dare not scrape for fear of scratching the tubing. How do you soften/remove the remaining fabric and glue residue? - Mike Since you are removing fabric, is it safe to say you will be stripping the frame and repainting? If you are doing the whole thing, it would make sense to inspect it, repair and paint, right? In that case, sandblast, or beadblast. If you are doing a small area, MEK will dissolve stink from sh*t. Watch prolonged exposure, and protect against skin absorbing the stuff, and breathing the fumes. Exposure is cumulative, and bad things happen. If you already knew that, sorry for you seeing it all written again. ;-) -- Jim in NC |
Nope; all fine - Mike "Morgans" wrote: "Michael Horowitz" wrote in message .. . When you remove fabric from a tube fuselage, the part that is glued down will be like concrete. I know I dare not scrape for fear of scratching the tubing. How do you soften/remove the remaining fabric and glue residue? - Mike Since you are removing fabric, is it safe to say you will be stripping the frame and repainting? If you are doing the whole thing, it would make sense to inspect it, repair and paint, right? In that case, sandblast, or beadblast. If you are doing a small area, MEK will dissolve stink from sh*t. Watch prolonged exposure, and protect against skin absorbing the stuff, and breathing the fumes. Exposure is cumulative, and bad things happen. If you already knew that, sorry for you seeing it all written again. ;-) |
| Thread Tools | |
| Display Modes | |
| Double covering fabric covered wings | [email protected] | Home Built | 9 | May 9th 04 09:39 PM |
| Fabric repair | D.A.L | Home Built | 0 | April 27th 04 08:17 PM |
| Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 12:37 PM |
| Fabric Work | Doug | Home Built | 9 | January 26th 04 04:31 AM |
| Need to learn dope and fabric work | David Hill | Restoration | 5 | October 9th 03 02:52 AM |
