Double covering fabric covered wings
Old May 6th 04, 02:35 PM
Default Double covering fabric covered wings
I just found out about a method being used by some experimenters to
cover their wings that is intriguing. They are literally covering the
wings twice with fabric.
The technique involves covering the wing initially with a heavy grade
fabric, taughten it with the iron as specified, apply the rib tape and
then stitch the ribs as normal. Up to this point, everything is
absolutely by the book.
But then, they apply a lightweight second layer of fabric on top of
the original covering using polytack. The second layer becomes a
defacto enormous tape. What I mean is normally, the next step after
stitching is to cover the stitches and leading edges with pinked
tapes. In effect this method is doing that, it's just that the tape
is the width of the entire wing.
This second layer is then ironed with the iron at it's lowest
calibrated setting.
I got to inspect two wings side by side, one with the finished double
covering and the other one with just the single fabric (prior to it
getting the second layer). The difference between the two wings was
incredible. The double layered wing seemed like it was covered with
sheet aluminum compared to the single layered wing. Snap your finger
on the double layered wing and you heard a reasonant "PING". Do the
same to the single layered wing and you hear a dull "thud".
The guy doing the covering said that he understood that this method
for wing covering was a certified process for the Beech Staggerwing.
He's seen several airplanes with the two layers at airshows and they
really impressed him.
Why would anyone want to do this? Well it makes a very stiff fabric,
no bulging up between the ribs. It also eliminates the pinked tapes
applied on top of the stitches and elswhere because the second layer
constitutes those tapes. There is much less sanding required because
you don't have to spray and sand around each of the pinked tapes.
Basically you just spray the proper silver and primer, scuff slightly
and you're ready for the color coat.
Has anyone else heard of this method?
Corky Scott
Fabric repair D.A.L Home Built 0 April 27th 04 08:17 PM
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 12:37 PM
Questions on covering Ed Home Built 3 March 16th 04 07:18 PM
Fabric covering processes Jerry Guy Home Built 2 January 29th 04 07:49 PM
Fabric Covered Dreams Jim Austin Home Built 4 August 13th 03 04:32 PM
