Best lubricant for Mechanical Tachometer Cable???
Old January 2nd 05, 06:02 PM
RonLee
Default Best lubricant for Mechanical Tachometer Cable???
My tach cable housing (Lycoming) leaks nasty black stuff so I cleaned
and dried it. What is the best lubricant to use? Particularly one that
does not deteriorate and leak through the housing. What about a
covering for the housing to prevent the leaking?
Old January 2nd 05, 08:15 PM
Cy Galley
The "nasty black stuff" is the graphite lubricant. The reason that it is
leaking is a bad tach drive seal in the tach drive adapter on the back of
your engine. This lets the engine oil wash the Black stuff thru the tach
drive housing. The housing should not leak under normal conditions so I'd
also check to see if the housing has a hole worn in the side.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
RonLee" wrote in message
Old January 3rd 05, 02:22 PM
Dan Nafe
The best way to deal with this is to replace your mechanical tachometer
with an electronic one from EI.
Old January 4th 05, 12:04 AM
Anthony W
Lube the cable with wheelbearing grease and if there are any cracks in the
plastic cover on the cable housing, you can recover it with heat shrink
tubing for about 2 bucks. I do this on motorcycle cables all the time.
Tony
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
rudder cable question Bob Loer Home Built 7 November 26th 03 08:34 AM
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 04:14 PM
