Glass big learning curve?
Old September 16th 05, 05:33 PM
Robert M. Gary
Default Glass big learning curve?
Our CAP unit is going to be receiving a new C-182 with a glass cockpit.
In order to give us a taste of it a Cirrus owner came to our CAP
meeting and showed us his wonderful aircraft (not the same PDF/MFD but
close). I've heard from many sources that it takes about 10 hours to
transition. In fact a local FBO has a brand new C-182 (rents for about
$200/hr) and requires 15 hours. Although I didn't fly the Cirrus, I sat
in the aircraft while the owner spoke with someone else. He said we
could push any buttons we wanted to. So, I tried to think of all the
things I could normally do on an IFR flight. Amazingly, I had no
problems with any of the operations. The display is easy for me because
my generation grew up flying flight simulators that use the exact same
display. The only hard part is figuring out the 430s (which I've done
before). So, I'm wondering if all this talk about a long transition
time is mostly for the generation that didn't grow up with computers.
Just thinking about the time it takes some people (not necessarily
based on age) to get familiar with their computer vs. others, I'm
wondering if its the same thing. Perhaps I'm being naive but I felt
that I could fly behind that panel today.
Has anyone on this list had experience with such a transition?
-Robert, CFI
Old September 16th 05, 07:29 PM
Michael
transition.
It depends on two things - how complete a transition do you want, and
what is your experience going in.
For a novice IFR pilot who wants (or maybe needs) all the automation
and functionality the system has to offer, it can actually take longer.
For an experienced IFR steam gauge pilot who only wants as much
functionality as he is used to having, 15 minutes is closer to the
mark.
That was my experience as well. The first flight I ever took in the
Cirrus, I needed about 15 minutes to come up to speed on how everything
worked. 30 minutes into the flight I was teaching the owner how to use
his engine analyzer to operate LOP. At the end of that flight, the
pilot botched an ILS approach enough to peg the GS needle (in IMC, but
with a fly-down indication). By then, I was so comfortable with the
plane, I was able to talk him through a recovery to the approach.
There is still functionality there that I can't effectively use, but
what I can use is way more than what I have available in my Twin
Comanche.
Actually, I think the long transition is for those who are not already
experienced steam gauge pilots. Think about this - did you learn how
to program the flight plan capabilities of the map display, or were you
doing it all in direct-to mode? I do the latter - after all, that's
all we ever had flying fix-to-fix with VOR/DME. Can you program the
vertical guidance for enroute descent, or do you just figure that at
150 kts you need 5 nm per 1000 ft at 500 fpm, and at 180 kts you need 6
nm? Basically, what I'm saying is that there is probably a lot of
automation capability you're not using, but as an experienced IFR pilot
you probably don't need it.
The all-glass Cirrus has a set of emergency instruments - a card
compass, an ASI, altimeter, and AI. It also has dual 430's. If the
PFD fails, the factory recommends you couple up the A/P to the 430 and
not try to hand-fly it. I would almost certainly screw up trying to do
that. On the other hand, I have no doubt I could fly a good GPS
approach simply using the 430 map and the available panel. Partial
panel with an AI? Luxury!
Basically, I think most of the people getting into the Cirrus are NOT
experienced steam gauge IFR pilots. They mostly don't have the skills
to effectively fly such a fast and slippery airplane IFR in IMC without
the automation the system offers. Therefore, they need the long
transition to learn how to use the automation. For someone with 100+
hours of actual in Mooney/Bonanza/Comanche or similar airplanes with a
steam gauge panel, the complex automation is not at all necessary -
thus his transition is quick.
Michael
Old September 17th 05, 04:55 AM
Victor
that.
I don't see how. Assuming your 430s have a flight plan and you're following
it, all you've got to do is engage GPSS and ALT. Or GPSS and VS and then
dial in the vertical speed you want on the autopilot.
Old September 19th 05, 06:17 PM
Michael
I would almost certainly screw up trying to do that.
You know, the A/P in my Twin Comanche can do wing level, heading hold,
and it can sort of track the LORAN but I don't like how it does that -
too much hunting. I put it in because I got it cheap. Altitude hold
would be nice, but installingthe pitch servo is a pain so I don't have
it. For years, I flew the plane night and hard IFR with no autopilot
at all. I still don't use it in IMC - it's for long boring stretches
of VFR flight.
I have actually flown planes that had GPSS, VS, and similar funtions.
GPSS is great when you know exactly how to engage it. I once borrowed
a Mooney that had an STEC and GNS430 with GPSS. Took me about 15
minutes to figure out why it wasn't working - silly me, I thought
following a GPS meant the A/P should be in nav mode. Nope, heading.
Honestly, if the weather had gone foul then, I would have disconnedcted
the silly thing and hand flown it instead of figuring in out.
I used to instruct a student in an Ovation that had the KFC autopilot.
Had to learn how to work it to explain it to him. He kept busting
through altitudes with that VS function. Turned out the solution was
to press one more button - and then it would say ARM and that meant
that when it reached the altitude preset it would level off. I'm not
sure I remember how to do it now.
Anyway, my point is that without the manual, I would likely not be able
to figure out how to press all the buttons to correctly couple up the
autopilot to the 430 for an approach. I'd get something wrong, for
sure. And all the button-pushing would distract me from doing my job -
that is, landing the damn airplane. And I can assure you that with a
moving map GPS, an AI, an ASI and an altimeter I can fly an approach
and land the plane - it's nothing compared to doing a partial panel VOR
with just a TC and compass, never mind an NDB.
Michael
Old September 24th 05, 04:16 PM
Roger
On 16 Sep 2005 11:29:13 -0700, "Michael"
transition.
I think it's highly unlikely the novice IFR pilot needs any where near
the full functionality, at least to begin with and definately does not
need it all at once.
If they get the system in incremental doses as needed it should barely
be noticeable.
mark.
Which is what the novice pilot should be doing instead of a full
indoctrination. I speak computereese and in a number of languages. I
sure didn't get all that in one shot.
Comanche.
Probably, but another problem is people thinking they need to know how
to do everything when they first go out such as FBOs and insurrance
companies wanting the renter, or owner to be proficient with every
thing the units are capable of doing before letting them fly the
airplane which is rediculous. These are things that are far easier to
use step wise than as a seperate entitie. Having taught computer
science at the university level, I'd guess the average indivudual
would take on the order of 10 times longer to learn how to use the
complete glass panel display the way most teach them compared to
learning to use the functions incrementally as needed.
I didn't gro up with computers, they didn't have them back then, but
I've had my own computer since late 1979 and that first one cost one
whale of a lot more than this 3.4 gig, 64 bit monster with 2 Gig of
RAM and half a terabyte of HD space plus large LCD monitor, slide/film
scanner, flat bed scanner, and printer. Actually it cost more without
monitor and keyboard than this one and the 3.2 Gig unit to the right
of me with 1.3 terabytes of HD storage including a 400 Gig RAID and
large monitors combined.
Come to think, it's more like the computers grew up with me:-)) They
feel like a natural extension and I find the glass panel flight
instruments more natural to use than the old "steam gauges".
Do it the simple way first. :-))
Nor does the IFR student, at least no all in one dose.
I think people make things too complicated.
Although I agree I think this may be a bit of mixing apples and
oranges. Most learn to fly instruments in relatively simple and
forgiving airplanes. (fixed gear and docile). If they learn to fly
the glass panels in 172s or 182s instead of the Cirrus or other high
performance aircraft and learn to use the instrument functions as they
need them it would be far easier and take less time. (The Cirrus is
every bit as complicated to fly as a Bonanza).
I'd liken the way it's being done now to doing primary training in a
Bo in IMC. They are slipery and you really need a good autopilot to
be flying one much in IMC. (It sure reduces the work load)
Transitioning to, or learning on a glass panel does not need to be
difficult or take hours and hours of training. To do so means some
very important steps have been left out of the learning cycle, or the
cycle was not taken in logical order.
www.rogerhalstead.com
Michael
Old September 24th 05, 07:37 PM
A. Smith
I don't know that I can agree with you Roger. I recently had a chance to
fly a Cessna 421C with the Chelton Synthetic Vision TM installed. I had no
previous experience with EFIS and had only a short time to read the basics
out of the manual. My flight was about 1 1/2 hours in VFR and I had a
safety pilot with me to watch for traffic as I knew I would be head down and
locked for a good portion of the time. The system presents an overwhelming
amount of information and it is shown in an unfamiliar format. I know it
would take me another 5-10 hours of flight time with the system before I
would be launching into any IFR flight that required an approach. I have a
good amount of time in the Cessna 421C so flying the aircraft is not a
problem, interpreting and following the EFIS is.
With all that being said the system is wondeful with what it can do and I
believe it is the way of the future. The only problem I see is pilots like
me who grew up on the gauges switching over to the tubes. The company that
owns the aircraft plans on putting it on a FAR 135 certificate. I am going
to try to follow it's progress to see if the FAA requires any special
training.
Allen
Old September 25th 05, 08:12 AM
Roger
On Sat, 24 Sep 2005 18:37:26 GMT, "A. Smith"
You are pointing out just what I said. The problems come when the
transition is attempted to be made in total instead of incrementally.
The learning pilot, whether IFR or primary student doesn't have these
problems, or shouldn't if the training on the glass panel is done
incrementally.
I like Michael's use of the Cirrus. It's an oft misunderstood
aircraft that is treated like other fixed gear aircraft when it should
be treated like high performance retracts without the option of using
the gear to slow down.
This is where trying to take in a complex system all at once is a poor
way to go. We don't teach computers that way and the glass cockpit
should not be taken on in that manner either.
As I said earlier, taken in a logical order although the logic might
vary some between pilots. Pilots and CFIs are not normally computer
people. They have a tendency, or I should say they feel an absolute
need to know the entire system before starting out. FBOs and
insurance companies tend to be the same. It's the wrong way to go.
First, Basic flight and engine instruments with basic radio and nav.
(no flight plans) to begin. Then GPS and moving map and on up the
chain.
training.
Allen
Old September 25th 05, 01:31 PM
A. Smith
"Roger" wrote in message
no
incrementally.
I see your point. If the glass panel can be learned from the ab initio
state it will just be normal procedure. I am looking at it from the
viewpoint of someone who has been flying gauges for years. You can't just
read the book, file a flightplan and blast-off into 200 and 1/2. Wouldn't
be prudent! (:-)
Allen
Old September 24th 05, 07:43 PM
Michael
I agree, but it's not the IFR student who needs the long transition.
It's the pilot with an instrument rating but not much IFR experience in
a fast, slippery (relatively - I'm talking Bonanza, not BeechJet)
airplanes.
You're right that the IFR student doesn't need the automation - because
he's not trying to fly halfway across the country through busy airspace
and scuzzy weather.
I agree with all of that. In my opinion, the Cirrus is actually MORE
demanding in IMC than a Bonanza, because the Bonanza gives you a very
effective option for slowing down (gear speeds are typically around the
150 kt mark), but the Cirrus does not and thus requires more advance
planning if you want to avoid being high and hot. Removing two levers
doesn't really make up for that.
If you take someone who can already fly IMC competently in a steam
gauge Skyhawk and put him into a glass Skyhawk, the transition will be
15 minutes or so - he'll get the fucnitonality he needs and can get the
rest later. The problem happens when you put him into a Cirrus.
Now he doesn't have enough cycles to fly the Cirrus - not because of
the glass, but because it's faster, less stable, and requires way more
advance planning. The correct solution is to develop his skills -
scan, control, and headwork - to where he can keep up with the more
demanding airplane. Unfortunately, all too often the 'solution'
offered is to substitute automation for skill.
Nobody can hand-fly a Bonanza (or similar airplane) SMOOTHLY while
copying a clearance, flipping through charts, and generally messing
with stuff. There will be minor heading and altitude deviations even
with the best of pilots. Also, nobody can hand-fly such an airplane
for hours (especially in the soup) without becoming fatigued. That's
why an autopilot is nice to have.
But there's a difference between minor heading and altitude deviations
and loss of control. Someone making the jump from a Skyhawk-class
airplane to a 300 hp Bonanza (or Cirrus) will likely lose control when
he tries to do several things at once. The solution is discipline and
training. Learn to have the approach (including the first segment of
the missed) briefed so you never have to do anything but fly once
you're inside the marker. Learn to divide attention and perform tasks
in short segments. The skills required are no different in the Cirrus
than they are in the Skyhawk, it's just that the Skyhawk lets you get
by with a lot more sloppiness. That's not a bad thing - it's the
reason why it's a whole lot easier to teach someone to fly instruments
in a Skyhawk-class airplane and then transition him to a Bonanza or
Mooney than it is to start in the fast slippery airplane. I know, I've
done it both ways.
The problem occurs when the pilot is told that the solution is not
skill development but automation. Instead of being told "If you have
to fly this plane partial panel, it will be more difficult so you need
more training and practice" he is told "You can't fly this plane
partial panel, so just couple up the autopilot to the GPS and have it
fly the approach" - which is, no ****, what glass-panel Cirrus pilots
are told. Instead of being told "you need to learn to divide your
attention between flying your existing clearance and checking your new
one" he is told "you need to learn how to enter your route into the
navigation computer and have it autosequence for you, so you can turn
the autopilot on at any time and keep it on as long as necessary."
Instead of being told "Now that you're flying higher and faster you
need to plan your descent" he's told "you need to program your Vnav
profile so it can prompt you for a descent and provide guidance."
As long as all the automation works, the Skyhawk IFR pilot can be a
Cirrus IFR pilot with his existing skill set - but then he needs to
learn how to use all the automation to make up for what he can't do.
Personally, I think that's a ****-poor way to do things.
Michael
Old September 25th 05, 08:43 AM
Roger
On 24 Sep 2005 11:43:12 -0700, "Michael"
snip
It's strange you should have brought up that particular item. My
first hour and eight minutes in the Deb were spent in a building storm
that was at least moderate turbulence, zero visibility and only my
second time in actual. I ended up flying the entire flight on manual.
Ask why I know to the minute the time we were solid IMC. GAWD, but I
was sick. Lunch bag tucked under my leg for quick access, turbulence
tot he point where it was almost impossible to hit the correct switch
without many tries, and torrential rain. At least we found no leaks in
the Deb.
Whipped at the end of the trip would be an understatement.
done it both ways.
In that case it's no wonder the insurance rates are so high.
This is no different than telling a VFR pilot to set the auto pilot
and let it fly if he/she runs into bad weather, or poor visibility.
You have not created a better pilot, you have given him/her a crutch
to make up for lack of skill which is a very poor teaching method and
dangerous practice.
It's a very dangerous way to do things.
It's great to do one the pilot is proficient in the particular
airplane and has become proficient with the systems, , but still the
learning of the glass panel needs to be incremental and not a
"all-at-once", or know it all before you type of thing.
Systems have a way of failing at the most inopportune time. That is
not the time to be using the system and autopilot as a crutch.
Michael
Cambridge 302 learning curve cont. Tuno Soaring 4 July 5th 04 10:10 AM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
learning curve in fs 2002.. David Ciemny Simulators 5 December 30th 03 12:18 AM
18m polar curve Alan Irving Soaring 1 December 15th 03 11:45 PM
Lesson in Glass JimC Owning 3 August 6th 03 01:09 AM
