Okay, I just found a way to avoid the silly mistake that I made. LPAero
will mail to you, for free, small pieces of window material so that you can compare with your current installation and determine best match. At my next flight physical I'll have to let the AME know what great 20/20 hindsight I have! JimC "JimC" wrote in message ... I finally got around to dealing with the pilot side window in my '79 Warrior. The window has had a crack in it from the day I bought it, which was about 15 months ago, and I've grown tired of looking at it. The previous owner had attempted to retrieve something from inside the plane by reaching through the storm window opening and pushed a little too much, creating nearly a 1 inch crack in the upper forward corner. I'd always planned to put in a new one and, now that I have the trim out for re-coloring, I decided it was a convenient time to take care of the glass. When ordering the new window I made an assumption ( now known to be a bad assumption ) that the glass in my plane was clear. I got as far as removing the old window and laying the new one next to it to compare, checking to see if the new one would need any edges trimmed before I realized that my old glass has a light gray tint. ARRRRRG *&$%#!. LESSON - Don't assume glass tint. Find a way to check it before ordering new. The light gray of old isn't that noticeable when viewed in the plane. I can only hope that the gray tint Plexiglas made today matches the old stuff as I'm off to get another window. Looks like E-bay for the new clear one. I can't return it because I bought the main glass and storm window separately and then assembled them. Heck, that's the only part of the new glass that has even had the protective plastic removed. I also hope there won't be any more lessons worth sharing by the time I get this completed ! JimC |
Thanks for the valuable lesson, Jim. I'll be going down that road someday,
and it'll be good to remember... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" "JimC" wrote in message .. . Okay, I just found a way to avoid the silly mistake that I made. LPAero will mail to you, for free, small pieces of window material so that you can compare with your current installation and determine best match. At my next flight physical I'll have to let the AME know what great 20/20 hindsight I have! JimC "JimC" wrote in message ... I finally got around to dealing with the pilot side window in my '79 Warrior. The window has had a crack in it from the day I bought it, which was about 15 months ago, and I've grown tired of looking at it. The previous owner had attempted to retrieve something from inside the plane by reaching through the storm window opening and pushed a little too much, creating nearly a 1 inch crack in the upper forward corner. I'd always planned to put in a new one and, now that I have the trim out for re-coloring, I decided it was a convenient time to take care of the glass. When ordering the new window I made an assumption ( now known to be a bad assumption ) that the glass in my plane was clear. I got as far as removing the old window and laying the new one next to it to compare, checking to see if the new one would need any edges trimmed before I realized that my old glass has a light gray tint. ARRRRRG *&$%#!. LESSON - Don't assume glass tint. Find a way to check it before ordering new. The light gray of old isn't that noticeable when viewed in the plane. I can only hope that the gray tint Plexiglas made today matches the old stuff as I'm off to get another window. Looks like E-bay for the new clear one. I can't return it because I bought the main glass and storm window separately and then assembled them. Heck, that's the only part of the new glass that has even had the protective plastic removed. I also hope there won't be any more lessons worth sharing by the time I get this completed ! JimC |
Glad to see you've made it back from another sojourn to the pilot's mecca,
Oshkosh. One of these days I will have to venture up that way in late July and take in the festivities. It really sounds fun. As for the side window, if you plan on changing yours anytime soon and you either have or plan to use the clear variety, let me know. This window fits your plane too. As a matter of fact, it fits almost all (maybe all) PA28 planes. Here is the list. Piper Cherokee Warrior PA-28-151 s/n 28-7415001 thru 28-7715314 PA-28-161 s/n 28-7716001 thru 28-8616057 s/n 2816001 and up Cadet PA-28-161 s/n 2841001 and up Cherokee PA-28-180 s/n 28-7405001 thru 28-7505261 Archer II PA-28-181 s/n 28-7690001 thru 28-8690056 s/n 28-90001 thru 28-90205 Cherokee PA-28R-200 s/n 28R-7435001 thru 28R-7635545 Turbo Dakota PA-28-201T s/n 28-7921001 thru 28-7921095 Cherokee Arrow PA-28R-201 s/n 28R-7737002 thru 28R-7837335 Arrow PA-28R-201 s/n 2837001 and up Cherokee Arrow PA-28R-201T s/n 28R-7703001 thru 28R-7803394 Turbo Arrow PA-28R-201T s/n 2803001 and up Arrow IV PA-28RT-201 s/n 28R-7918001 thru 28R-8218039 PA-28RT-201T s/n 28R-7931001 and up Cherokee PA-28-235 s/n 28-7410001 thru 28-7710089 Dakota PA-28-236 s/n 28-7911001 and up "Jay Honeck" wrote in message news:xZyXa.64954$Ho3.9068@sccrnsc03... Thanks for the valuable lesson, Jim. I'll be going down that road someday, and it'll be good to remember... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" "JimC" wrote in message .. . Okay, I just found a way to avoid the silly mistake that I made. LPAero will mail to you, for free, small pieces of window material so that you can compare with your current installation and determine best match. At my next flight physical I'll have to let the AME know what great 20/20 hindsight I have! JimC "JimC" wrote in message ... I finally got around to dealing with the pilot side window in my '79 Warrior. The window has had a crack in it from the day I bought it, which was about 15 months ago, and I've grown tired of looking at it. The previous owner had attempted to retrieve something from inside the plane by reaching through the storm window opening and pushed a little too much, creating nearly a 1 inch crack in the upper forward corner. I'd always planned to put in a new one and, now that I have the trim out for re-coloring, I decided it was a convenient time to take care of the glass. When ordering the new window I made an assumption ( now known to be a bad assumption ) that the glass in my plane was clear. I got as far as removing the old window and laying the new one next to it to compare, checking to see if the new one would need any edges trimmed before I realized that my old glass has a light gray tint. ARRRRRG *&$%#!. LESSON - Don't assume glass tint. Find a way to check it before ordering new. The light gray of old isn't that noticeable when viewed in the plane. I can only hope that the gray tint Plexiglas made today matches the old stuff as I'm off to get another window. Looks like E-bay for the new clear one. I can't return it because I bought the main glass and storm window separately and then assembled them. Heck, that's the only part of the new glass that has even had the protective plastic removed. I also hope there won't be any more lessons worth sharing by the time I get this completed ! JimC |
I had not studied the list that closely, but you're probably right. I
noticed that the 140's are also missing. They are in the PA28 family too, right? I'm just glad that it fits so many of Piper's tribe. That increases the probability that I'll find a new owner for the window :-) JimC "John Galban" wrote in message om... "JimC" wrote in message ... As for the side window, if you plan on changing yours anytime soon and you either have or plan to use the clear variety, let me know. This window fits your plane too. As a matter of fact, it fits almost all (maybe all) PA28 planes. Here is the list. snip list From the list, it looks like it'll fit the post '73 models, but not the earlier PA28s. John Galban=====N4BQ (PA28-180) |
| Thread Tools | |
| Display Modes | |
| Glass Goose Website revamped | wingsnaprop | Home Built | 5 | December 15th 04 04:56 AM |
| Glass Goose Website revamped | wingsnaprop | Home Built | 0 | December 14th 04 03:58 PM |
| IFR Practice Lesson Learned | Matt Young | Instrument Flight Rules | 1 | July 10th 04 10:04 PM |
| 2 glass HUD question | Jim Yanik | Military Aviation | 0 | January 30th 04 03:22 AM |
| Glass Goose | Dr Bach | Home Built | 1 | August 3rd 03 06:51 AM |
