Installing an ELT antenna.
Old September 26th 05, 03:13 PM
Default Installing an ELT antenna.
Any advice out there re the preferred location for an ELT antenna in a
Ventus 2 ? With a Carbon fiber fuselage its not obvious to me the best
place to install the antenna ( Ameriking supplied - about 20 inches
long ) The factory suggests "under the canopy" , but to me I can't see
how to do that easily . All suggestions welcome .
Ron Clarke (ZA)
Old September 26th 05, 03:51 PM
bumper
Options are limited if you don't want an external antenna. If the area over
the spars is fiberglass, you could use the "Bob Archer Sportcraft" folded
dipole, which is flexible and can be mounted to the inside of curved
surfaces. Dimensions are 12" X 26.5", mod SA-006, from Chief Aircraft $82.50
US.
You might be able to find a home for this antenna somewhere else, like under
the glareshield, if there's room.
One could also make their own dipole antenna by separating the inner
conductor and outer shield, then extending same in opposite directions (or
alternately soldering the coax conductors to two strips of copper foil or
wires). The total length of the antenna, both sides, for 121.5 Mhz, would be
about 3ft.10-1/4in. or 1.174 M.
Since response to 121.5 MHz ELTs is scheduled to end in 3 years, I purchase
a 406 MHz PLB w/ built in GPS for $500 USD ($550 before rebate - - which I
haven't received yet!). This unit must be tripped manually, is registered to
me, and can attach to parachute harness etc.
good luck
bumper
Ron Clarke (ZA)
Old September 26th 05, 06:11 PM
Bob Kibby
I also have one of the new PLBs on my parachute harness but understand that
it does not satisfy the US Competition requirement for an ELT in 2006 since
it is not "g" activated.
Bob Kibby "2BK"
purchase a 406 MHz PLB w/ built in GPS for $500 USD ($550 before
rebate - - which I haven't received yet!). This unit must be tripped
manually, is registered to me, and can attach to parachute harness etc.
good luck
bumper
Old September 26th 05, 06:40 PM
Mike the Strike
Oops. I mixed up two replies. My transponder antenna is the current
problem. My ELT antenna is a rubber duckie mounted at the rear of the
canopy rail. Probably the quickest and cheapest solution.
Old September 26th 05, 07:11 PM
bumper
"Mike the Strike" wrote in message
Oh, okay. Transponder antenna it is, then.
I know that some have mounted their transponder antenna up forward of, or on
the glareshield. I'm not comfortable with this due to RF exposure concerns.
Also, since it is arguably more important to give ATC a good view of your
antenna, the bottom of the aircraft is the optimal location.
If the ship fuselage is glass, an aluminum plate, for a ground plane and
mount can be installed within the fuselage. DG shows examples of this on
their website. However, if the ship is carbon, then the antenna will
probably have to go on the outside. My ASH26E has it just aft of the left
gear door. It's the little stub monopole antenna (costs 35 to 45 bucks US)
you see everywhere. Mounted on carbon, it needs no additional ground plane,
but if one desired, some copper or aluminum foil or sheet could be placed
inside.
This location, while not immune from trailer hits, is relatively easy to
avoid, at least on the 26E. In the case of a gear-up, which isn't on my
remaining short list of things to do, unlike a blade, it won't try to
protect itself by destroying a chunk of fuselage.
all the best,
bumper
Old September 26th 05, 07:31 PM
Marc Ramsey
A blade can be mounted on the lower fuselage such that it is not
vulnerable to gear-ups or trailer hits. If it is possible to reach far
enough back in the fuselage, it can be mounted on the center line where
the fuselage curves upwards toward the tailboom. Otherwise, it can be
mounted behind the gear well, offset from the center line just enough
that it does not extend below the lowest part of the fuselage.
Marc
Old September 26th 05, 07:30 PM
Paul Remde
Hi Ron,
Some of the replies to your post on r.a.s. mentioned short stub antennas and
spade antennas. They are designed for use with a transponder which use very
different frequencies than an ELT.
The ELT you purchased will transmit on 121.5 MHz and 243 MHz.
I see that Wings and Wheels offers a small rubber ducky antenna he
http://www.wingsandwheels.com/page14.htm I don't have any idea whether that
solution would be acceptable to the FAA or how the transmit output would be
affected, but it is a simple solution. I can't say that I recommend it, but
I don't know what else to suggest. The disclaimer note on Tim's web site
is, "note: this may not be suitable for installations that require
certification,
but ELT's are not required in sailplanes and can use this for an added
safety feature."
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
Ron Clarke (ZA)
Old September 27th 05, 01:31 AM
Roy Bourgeois
Ron:
My ACK ELT antenna in my Nimbus 3 is installed lengthwise, in line with the
fuselage, under the instrument panel (glare shield) cover. I used plastic
tie wraps to secure it to the panel cover. By all reports it puts out a
good signal. My transponder antenna is a 2.5" stubby located vertically on
the fuselage aft of the turtle deck with a 10" aluminum pie plate ( from
the supermarket!) inside the fuselage surrounding the base of the
antenna ATC says it also puts out a decent signal.
Roy B.
Old September 27th 05, 11:09 PM
5Z
In my ASH-26E, the ELT is located by my left elbow, and the entenna is
the wire whip installed in the baggage area above the spar, as the is
the only non-carbon skinned part of the glider.
I didn't bother with a ground plane as I figure amny chrashed airplanes
also may not have a ground plane to work with...
The antenna is mounted to an aluminum bracket behind my left shoulder,
and curves around the inside of the baggage area toward the rear and
right side. Springiness keeps it nicely pressed against the top of the
fuselage.
As for transponder, I had the factory install it, as the cost was
essentially parts - something like $120 four years ago. I still
haven't installed the transponder itself, but am running the antenna
through a regimen of abuse as it occasionally catches on the trailer.
The antenna is installed through the fuselage just aft of the wheel,
and there is no added ground plane, as I assume the carbon skin is good
enough.
-Tom
Old September 27th 05, 02:46 AM
Ian Cant
As a general rule, it's better not to ask if the answer
might be unpleasant.
Ian
At 00:36 27 September 2005, Jphoenix wrote:
Marc,
Perhaps we could have the SSA government liaison (or
SRA dude) ask all
these questions directly to the FAA. Specifically:
Can a private pilot glider install his own ELT in his
own experimental
glider and sign it off?
Does a TC'd glider need a 337 form completed and approved
(major
alteration)?
Does a glider with an ELT installed have to meet all
(or some) of the
requirements of 91.207?
With an official FAA answer to these questions, and
perhaps some more I
didn't think of, we can avoid uncertainty over what
rules apply and how
they apply, etc.
I think it is fairly clear that for a glider with
an experimental
certificate, you can pretty much install an ELT any
way you want, and
likely get away with signing it off yourself (as a
non-A&P). I think it
is also fairly clear that an ELT installation in a
type certified glider
will require at least an A&P (and possibly IA) sign
off, but probably
does not require a 337. The question in my mind,
however, is whether
the typical A&P (or IA) would be willing to sign off
an ELT installation
in a certified glider, that makes use of uncertified
components (like a
rubber ducky). Any A&Ps out there willing to comment?
Marc
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 05:34 PM
LS-4 Transponder antenna location? Matt Herron Soaring 3 February 25th 04 03:45 PM
