90 degree locking pliers?
Old October 1st 05, 03:02 AM
B. Jensen
Default 90 degree locking pliers?
Does anyone know of a long nose vise grip plies that is bent 90 degrees?
I have a needle nose pliers that is bent 90 degrees at the tips, but
I sure could use a locking pliers with the same setup.
Thanks,
BJ
Old October 1st 05, 11:01 PM
Cy Galley
Why not buy a straight pair and heat and bend to your specs?
"B. Jensen" wrote in message
Does anyone know of a long nose vise grip plies that is bent 90 degrees? I
have a needle nose pliers that is bent 90 degrees at the tips, but I sure
Thanks,
BJ
Old October 2nd 05, 04:11 AM
Morgans
The way I am seeing his question, the action of plyers, with a typical pivot
point, would only make the gripping surfaces slide past each other, and not
grip anything.
It seems like what is needed is a new type of tool, with a right angle on
the end, and a screw pushing the other grip towards the right angle one.
Jim in NC
Old October 2nd 05, 05:50 AM
bowman
pivot point, would only make the gripping surfaces slide past each other,
and not grip anything.
http://www.etool.ca/eTool/RENDER/1/26/220/3122.html
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old October 2nd 05, 05:46 AM
Andy Asberry
On Sat, 1 Oct 2005 23:11:56 -0400, "Morgans"
grip anything.
Picture the bend 90 degrees to the side.
Old October 2nd 05, 02:34 PM
Michael Pilla
"Morgans" wrote in message
grip anything.
Jim in NC
Go to Home Depot. I have a pair that I use quite often. The angle isn't
quite 90o, but close enough.
The jaws are much thinner than the usual vise-grip pliers; more like a
long-nose pliers, bent at an angle in the same plane as the handles. I have
not seen any vise-grip type pliers that have the jaws bent at an angle to
the plane of the handles.
I did find that if one tried to apply too much pressure, the jaws would slip
out of alignment. The regular vise-grip pliers can exert quite a force, if
needed, but the angled, "long nose", type can only exert a moderate force.
I cannot check the brand / model because it is packed away pending a move
out of state.
Michael Pilla
Old October 3rd 05, 01:42 AM
grip anything.
Uh, don't they call those monkey wrenches?
Maybe they have another name for the small ones.
FF
Old October 3rd 05, 02:33 PM
Michael Pilla
pivot
not
grip anything.
FF
All my monkey wrenches are tightened via a knurled screw whereas the
vise-grip pliers are tightened by squeezing the handles over center after
adjusting the approximate grip range; rough description.
Michael Pilla
37 Degree Single vs Double Flared Tubing Craig Foster Home Built 1 July 21st 04 03:24 PM
37 degree fitting Ernest Christley Home Built 8 June 17th 04 03:29 AM
90 Degree turn while slipping ISoar Soaring 40 February 14th 04 10:49 AM
Advice on flying Pitts with Haigh Locking Tailwheel Ditch Home Built 19 January 4th 04 10:18 PM
