37 Degree Single vs Double Flared Tubing
Old July 19th 04, 02:23 AM
Craig Foster
Default 37 Degree Single vs Double Flared Tubing
Do aluminum fuel lines need to be double flared (37 degree flaring)? A 37
degree double flaring tool is very expensive compare to the single flare
type. I ran across this in a Car Craft magazine article:
"Most tubing in the aircraft industry is extruded in one piece with no seam,
so double flares aren't required to prevent crack formation."
Old July 21st 04, 03:24 PM
For a one-time use, I bought a cheapie $10 45 degree flaring tool, took the
taper off, and recut it in a lathe to 37 degrees. YMMV
-Cory
Craig Foster wrote:
: Do aluminum fuel lines need to be double flared (37 degree flaring)? A 37
: degree double flaring tool is very expensive compare to the single flare
: type. I ran across this in a Car Craft magazine article:
: "Most tubing in the aircraft industry is extruded in one piece with no seam,
: so double flares aren't required to prevent crack formation."
* Cory Papenfuss *
* Electrical Engineering Ph.D. Graduate Student *
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
