Transponder
Old October 17th 05, 01:29 AM
Tom Cummings
Default Transponder
My King KT-76A transponder has a stuck "Ident" button.
It stuck when activated for ATC on the last flight and the button appears to
have colapsed sideways underneath the cover panel. It is no longer visible
in the opening now. ATC says the unit indicates an "Indent" signal
presently.
Does this require an avionics shop to repair or could it be a simple matter
such as removing the unit, then remove the cover plate and look for a
colapsed return spring?
Thanks,
Tom
Old October 17th 05, 02:17 AM
Default Transponder
presently.
Thanks,
Tom
When I read a message like this it scares me to think you're sharing IFR
airspace. Hopefully, it's in not in conjested airspace.
Old October 17th 05, 08:53 PM
Default Transponder
Matt Barrow wrote:
Tim's good for that!
When logic and rebuttal fails, personal attack usally makes some folks feel
good.
Old October 17th 05, 05:55 PM
Mitty
Default Transponder
Simple is the operative word.
Look in a mirror, see simple.
If he can't afford to have an avionics shop repair
his transponder, then he shouldn't be sharing the airspace with me where TCAS
depends upon his properly maintaining his transponder.
Financial capability is hardly the only possible explanation for his interest in
repairing the box himself. Some people, myself included, like to do things for
themselves. Obviously, this has to be done judiciously in the aviation context
but that doesn't mean minor things can't be dealt with. The OP is trying to
find out if this is a minor thing.
You would benefit from reading a book called "Millionaire Next Door." For all
you know, the OP might be one of them.
There is also one called "All I Really Need to Know I Learned in Kindergarten."
Among its admonitions a "Don't hit people." and "Say you're sorry when
you hurt somebody."
Jeez I hate these off-topic posts. I'll stop now.
Old October 17th 05, 08:43 PM
Default Transponder
All of that is a real stretch.
Old October 17th 05, 05:29 AM
Ray
Default Transponder
I don't see why it should be a big deal. ATC has the capability to
receive multiple idents simultaneously. I would imagine most
controllers can deal with this kind of problem without skipping a beat -
even if you're VFR and not in contact with ATC.
- Ray
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Transponder petition Ian Cant Soaring 11 February 28th 04 06:38 AM
More on transponder petition Ian Cant Soaring 1 February 27th 04 06:37 PM
