Out of annual....
Old October 29th 05, 01:37 PM
A Lieberman
Default Out of annual....
and back in the saddle, but not without a little excitement *smile*.
30 hours later, $1,700 less in my wallet and new wheel bearings to show for
it, I decided to take a short hop from KMBO (Madison, MS) to KJAN (Jackson
MS) which was a whole 9 NM to pick up a passenger who was coming in on a
commercial flight.
Runup, smooth as silk, preflight, nothing unusual, launch into the wild
blue yonder. Land at JAN, pick up the passenger, and figured everything
looked cool for a 30 minute cross country trip.
Fire up the engine, everything running smooth, taxi out to 34R, check
controls, check the L mag, and real rough engine. Check the right mag,
smooth, both setting smooth engine. Thinking hell, something not right,
lean it, try again, no success. Call ground with request to taxi back to
maintenance, 180 on taxiway approved, and shut down. A&P pulls cowling and
sure enough 1 plug wire dangling, and one wire you could see the threads
and it was not tightened down.
So..... he hooks up the wires, put the cowling on and we start up again.
Everything was cool on runup, but instead of going to Hattiesburg MS, I
told my passenger, we will put the plane through it's paces in the practice
area and go the next day. No other incidents, so I am cool for the next
year *smile*.
I was really impressed with this safety check. Had I not done a mag check,
or skipped it for any reason, I would have never detected a problem.
Engine was purring like a kitten in spite of only running off of 7 spark
plugs.
So, the real moral of this story is to stay within range of your airport.
One really never knows....
Allen
Old October 29th 05, 02:16 PM
Mike Spera
commercial flight.
So, was the dangling wire and loose nut how the shop left the plane
after its annual?
Thanks,
Mike
Old October 29th 05, 03:12 PM
A Lieberman
commercial flight.
after its annual?
Mike,
MY GUESS is that the plug wire was not tightened and fell out in flight.
Reason I say this, is the mag check passed on my outbound flight to JAN. I
would have never had launched out of MBO for as rough as the MAG check was
at MBO.
It was at JAN, on my second runup where this was discovered.
I have NEVER had a problem with the shop where I am having my plane
maintained.
Human nature does prevail, but Murphy lives too! Fortunately, Murphy was
defied on the ground thanks to this safety check.
Allen
Old October 29th 05, 03:19 PM
A Lieberman
at MBO.
CORRECTION:
Above should read:
at JAN.
Allen
Old October 29th 05, 02:51 PM
On Sat, 29 Oct 2005 07:37:08 -0500, A Lieberman
snip
This is a customer relations make-or-break situation-I won't get into
the obvious safety of flight issues. I would like to think that some
serious forelock pulling took place on the A&P's (and his
supervisor's) part.
Closest I ever came to this situation was with a Saratoga back in the
80's. After my post-inspection test run, I shut off the engine with
the fuel selector. Old habit-long since "revised".
Did the delivery pitch to the owner, went back in and started working
on something else. "ummm, my airplane won't start". Walked out, turned
the fuel selector on, apologized sincerely, went back to work.
snip
Typically put 10-15 minutes on after any engine maintenance/annual
inspection, 60-90 minutes on a "new" cylinder/engine install before
returning it to the owner.
Only ever had one customer complain. I asked him if he would rather
fly around the pattern for 45 minutes waiting for something to fail.
He then decided that me doing it for him was acceptable.
TC
Old October 29th 05, 03:56 PM
Nathan Young
This is why I pull the top cowl on my Cherokee 180 after any A&P
maintenance. My A&P does a great job (and I'm yet to find anything),
but you never know. This is also an easy task to do on a 180 - takes
about 1 minute. I know other planes are much more difficult.
I also always make a local area flight after each maintenance. This
flight is within gliding range of the runway at all times.
After that - I never fly in IMC for my first XC out of maintenance.
Perhaps these are over conservative guidelines, but I've read too many
accident reports where the plane was on its 1st flight after
maintenance.
Old October 29th 05, 04:40 PM
: After that - I never fly in IMC for my first XC out of maintenance.
... and then there's this friend of mine. He (with the assistance of a very
competent, capable mechanic) re-timed the mags on his Cherokee 6 at an airport about
50 miles away from "home". This was after a much less-than-competent mechanic
mis-timed them due to the impulse couplings.
After timing, and running up, he took off IFR in 0/0 so bad that the mechanic
had a hard time *driving his car* home! There's a distinct "clanging" sound you hear
as he walks by...
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
My Aztec's first Annual Louis L. Perley III Owning 11 November 11th 04 05:04 AM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 07:20 PM
Annual Report Final. "Long" NW_PILOT Piloting 22 October 28th 04 07:20 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
