Christmas Annual - long drivel
Old December 20th 04, 07:33 PM
Denny
Default Christmas Annual - long drivel
Fat Albert the Apache needed his annual exam... When I bought him the
annual was in the summer and I have been gaining a month a year on
that... This year we moved it into December 1st... The annual usually
takes 3-5 days, but this morning he still sits in the shop with the
starboard engine uncowled after 3 weeks... I have been proactive in
doing preventive maintenance between annuals and normally we breeze
through the annual... This year there were two AD's that needed to be
satisfied...
One was the flap torque arm and torque tube... This is pretty straight
foward... We pulled them out (labor hours) and although they were
perfect the AD is recurring annually as long as the original parts
remain... I ordered the steel torque tube (~1.5" x 36")to replace the
aluminum tube and it was $400 (hey, it's for an airplane)... The torque
arm however was a nine inch long, $1600 item for something that any
competent machine shop would make from scratch for $40 in material and
a $150 in labor and CNC machine time - Piper's price is big time rape!
Steve, the mechanic, was really po'd at Piper over this part... He
finally found a serviceable part from a wrecked plane that met the AD
and was available for 50% of new, so we went that route...
The other AD was the pressure test on the heater can... Of course it
has a small crack, but worse it had been welded before (no entry on the
logs) so it was DOA... Plus the Southwind heater would continue to be
a recurring AD... The heater shops wanted $1800 to zero time the
heater, plus $650 to replace the solenoid fuel valves... A search was
started and we wound up with C&D which is just downstate from us...
They have PMA for a brand new heater which wound up being $3200 by the
time it was delivered... The big labor costs in this are the install
and the new panel switch and wiring.. But, I have a no AD heater,
which is new and shiny and has a warranty...
Next on the hit list was that the port engine backfired when I started
it up to fly over to the shop for the annual, ran rough for 10 seconds
then smoothed out (picture me with raised eyebrow and cringing wallet)
it has never done this before... When we got to the shop the first
thing we do is a compression test while the engine is hot... #1
cylinder on port side has zero compression... Pull the rocker cover and
sure enough the exhaust valve lacks about a sixteenth of an inch of
closing... So, Steve drives the valve out, reams the guide (carbon
buildup, no warpage) and reassembles... Borescopes the cylinder and
pressure tests again, all OK now... So more bucks for labor...
The other item on the hit list was that the starboard engine has been
gradually running leaner over a period of months.. In cruise the
starboard mixture knob is now an inch and a half ahead of the port
mixture knob for the same egt... It has been looked at twice with no
obvious leaks... With the engine totally uncowled we go after it with a
vengence... The induction hoses and clamps are replaced with new, and
all new intake gaskets... Pressure testing shows bubbles where the
induction tube for the #1 cylinder is pressed into the oil pan... This
is sealed up... The engine is test run, and the cowl is replaced...
Annual is finished and I'm to test fly it... The flight delivers no
joy with the starboard engine still considerably leaner than the port
engine, even at full rich on both mixtures... Ah jeez! So, back in
the shop, off with the cowlings (half an hour for two mechanics), and
we start glaring at the carburetor... The throttle shaft has some slop
in it, but the throttle shaft on the port engine, which runs fine, is
looser still - and we don't think that is the problem... After
considerable peering and poking and wiggling we (three of us by now)
decide that the shaft on the mixture has too much play... So off comes
the carburetor (more labor time as it is well buried...
Up on the bench we disassemble the carb... The mixture shaft is worn
and the brass washers show eccentric wear... A parts count and
comparison to the manual shows an O-ring is totally missing... This
could upset the air pressure above the fuel at the main metering valve
down in the bowl... OK, so we stop for the night... The next day Steve
calls Lycoming and talks to their carb expert... He opines that the air
leak around the mixture shaft will cause the engine to run lean... He
wants $450 for a rebuild kit... A call to avial shows that they want
$1000 for a rebuilt carb... I say let me think about it and go home...
A bit of skulking on the web brings up aircraft spruce as having a
rebuilt carb in stock for $529... It is ordered, next day air for an
extra 40 some bucks... The carb is put on, the engine test run, cowl
put on, and the plane is ready for a test flight...
So, I hurry through the office Saturday and manage to get in a days
work and be out to the airport with daylight left... Everyone is all
smiles, so in anticipation of delivering the plane back to the home
field it is fully fueled, etc.. The wind is from the same side of the
field as the shop, so we have to taxi 3/4 of a mile.. By the time I get
to the runup pad the starboard engine is wallowing and slowly winds
down and quits... Pat, the mechanic, who is in the right seat peers out
and says, hmmm there's fuel dripping off the cowl... (&*%#$@ bad word
said) We limp back to the shop on one engine (twins taxi terrible on
one engine)...
Testing at the shop shows fuel running through the carb... Off come the
cowls and the carb... Monday morning (today) Kelly Aerospace is called
and the problem discussed... They want the carb back for examination
and will ship me a replacement carb same day as mine arrives there...
So here we go with a round of $60+ next day shipping charges... I was
going to wait until the annual was over to post this, but who knows
when that will be... Anyway, the fun meter has passed $9,000 and is
still running...
Cheers...
Denny of the Lean Wallet, and Fat Albert the Apache
Giving thanks this Christmas, by Phill Coleman Otis Willie Naval Aviation 0 December 18th 04 06:52 AM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 08:20 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 04:41 PM
Another Almost Annual Christmas Poem!!! David Pincus Home Built 4 December 28th 03 01:47 PM
MERRY CHRISTMAS JSH5176 Military Aviation 0 December 13th 03 06:12 AM
