"Ringworming" and repair
Old November 20th 05, 11:44 PM posted to rec.aviation.homebuilt
Default "Ringworming" and repair
Am I correct that 'ringworming' is caused by the placticizers's having
evaporated form a dope finish, and the condition can be corrected by
re-introducing placticizers via a 'rejuvinator' ?- Mike
Old November 21st 05, 11:59 PM posted to rec.aviation.homebuilt
On Sun, 20 Nov 2005 18:44:41 -0500, Michael Horowitz
Ringworming? I thought you had to go to the Doc for some ointment to
cure that.
www.rogerhalstead.com
Old November 23rd 05, 12:40 AM posted to rec.aviation.homebuilt
I believe this is true. However, if the dope was painted with some
sort
of enamel, you will need to deal with the paint first.
I'd hope you can get a better answer from the group. I barely passed
the fabric & wood part of the A&P but I did own an airplane with
ringworm once.
Bill Hale
Old November 23rd 05, 03:38 AM posted to rec.aviation.homebuilt
Yes,
Rejuvinator can be sprayed on the existing dope. It will make it look
like new.
Quite often ringworm can be fixed with rejuvinator and a finger,
carefully working the dope together.
i did it on an old tripacer I owned and worked like a charm.
On some of the ringworm repairs i had to spray a little color dope to
make it blend in better.
Good luck
Dave
De-ice boot repair gbessert Owning 3 August 29th 17 07:30 PM
Dittel Radio Repair [email protected] Soaring 4 July 22nd 05 12:02 PM
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 01:41 PM
Advised on FAA Repair Station outside USA tbm700 Owning 0 September 23rd 04 05:50 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
