Calibrate? Repair? Adjust?
Old April 3rd 05, 06:29 PM
RST Engineering
Default Calibrate? Repair? Adjust?
A recent thread on what a person with an FCC license would have to do to
install/calibrate/repair/adjust radios led me to do the research that I
generally wind up doing once a year when this thread comes around again.
Let's talk about the plain old airframe mechanic ("AM") and the feller with
the FCC radiotelephone certificate ("FC").
Part 43 of the regulations specifically state that there are two categories
of "calibration" that are major repairs -- "calibration of and repair of
instruments. Calibration of radio equipment."
Note that Part 43 cleverly left OFF repair of radio equipment, while it
retained it on instruments. The FAA ain't dumb; they've got a stable of
lawyers writing this stuff. If they had MEANT to include repair of radio
equipment under major repair, they would have done so. They did not.
So let's go to Part 65 to see what AMs *are* allowed to do. 65.81a allows a
AM to "perform maintenance ... on appliances ... except ... repair to
instruments." Note again the clever mention of instruments and the
non-mention of radio equipment.
So we see that AMs with the requisite experience (again, "...the AM ... may
not perform the maintenance or repair ... unless he [sic] ... has performed
that maintenance at a prior time ...") may, in fact, repair radios. They
just can't CALIBRATE them when they are completed with the repair.
Since 14 CFR Part 1 does not define "calibrate", we have to turn to another
authority. In general, the courts have held that in the absence of a
specific definition of the controlling authority, or a generally accepted
practice in the industry, a recognized dictionary definition may be used.
Webster says that calibration is " ... to correct the graduations of a
measuring instrument (as in a thermometer). Is "alignment" calibration?
Not by this definition. Is "adjustment" calibration? No.
So let's turn our heads from radio repair to "instruments". What is an
instrument? Clearly, airspeed, gyroscopic indicators, pressure,
temperature, and those sorts of things are instruments. Indeed, Webster
comes to our help once more with a definition of instrument as "...a tool or
implement, especially one used for delicate work or for scientific or
artistic purposes." This is a particularly lousy definition for an aircraft
instrument, but let's build on it.
The specific question is whether or not a VOR head is an "instrument" in
light of the above. I can argue both ways and make good argument that it is
either a "radio" or an "instrument" depending on how we view it. So, can I
legally repair a VOR head? I argue that this is a truly gray area open to
MUCH interpretation and argument and I can sit on either side of the table
with some degree of comfort.
Now, during an install, a radio needs a couple of adjustments. Sidetone and
modulation level come to mind quickly. Since AMs can repair and align,
saying that they can't touch the installation controls is an absurdity.
However, adjustment of the modulation level CAN cause distortion and
splatter, so in this ONE ISOLATED case, I can argue for the need of a FC
certificate to make the adjustment. Otherwise, it is a pretty piece of
paper to hang on the wall.
Draw your own conclusions. It is your certificate on the line, and I'm not
going to argue with your interpretation. Nor am I going to argue with your
FSDO's interpretation. Interpretations are just like assholes, everybody
has one and most of them stink.
Jim Weir
A&P, IA
FCC 1st phone since 1959 (yes, that means I got it at 16)
Old April 3rd 05, 07:40 PM
houstondan
RST Engineering wrote:
Jim Weir
A&P, IA
man, had not heard the term "first phone" (s/b fone) in a very long
time. got mine at age 18, 1965, and it was my ticket to radio stardom
reading hog and corn prices and "music to milk by" at a 250 watt peanut
whistle day-timer. yes, the antenna dummy load was a light bulb. "thump
that biggun in the back...looks a litle gassy..." reading base-currents
in a blizzard on a 5 tower array.
always thought it was a come-down when they replaced 'first class' with
"general".
but i digress....sorry,
dan
Old April 3rd 05, 10:56 PM
kontiki
"general".
Me too... I never did renew my ticket after that.
Old April 4th 05, 01:41 PM
Ron Natalie
I still consider the entire radio to be connected to be part of the landing
light circuit :-)
De-ice boot repair gbessert Owning 3 August 29th 17 07:30 PM
Advised on FAA Repair Station outside USA tbm700 Owning 0 September 23rd 04 05:50 PM
Cirrus canopy frame repair Louw Pieters Soaring 0 May 29th 04 06:09 AM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
Terra Switch repair George A. Graham Home Built 1 October 25th 03 12:15 AM
