An OT query for folks here. While discussing things that can happen between the jetways, I posited that it's a really bad to be aloft in Big Iron in a medical emergency, etc. -- based on how long it takes to get on the ground. That brings up the question of how long that time really is.... So: If you are at cruise in Boeing's finest at FL430 & declare an emergency; how fast CAN you be down and stopped? (Or Airbus, for that matter....) Assuming ATC can clear a lane, I assume it's a function of how steep a decent you can use without exceeding the max IAS. What are the limits on speed brakes, dropping gear, etc. to dirty things ups? Do you slow to gear-down speed, drop them, then nose over? Or is the higher speed possible w/ gearup better? -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
If you are directly over the airport you can land at, then follow the
emergency decent procedures for that plane (and they differ from plane to plane) and come down about 2000 fpm (I really don't know, and it would depend on the plane), but lets use that figure. Then it would take 21 1/2 minutes to get down and maybe 1 1/2 minutes in the pattern and 1 minute of taxi, so that is 23 minutes, assuming the airport is at sealevel. That would be fast. |
Hmm, make that 24 minutes.
2000fpm is not even a "normal" rate of descent in a jet. At 450kts, 2000fpm
is less than a 3% gradient! Mike MU-2 "Doug" wrote in message ups.com... If you are directly over the airport you can land at, then follow the emergency decent procedures for that plane (and they differ from plane to plane) and come down about 2000 fpm (I really don't know, and it would depend on the plane), but lets use that figure. Then it would take 21 1/2 minutes to get down and maybe 1 1/2 minutes in the pattern and 1 minute of taxi, so that is 23 minutes, assuming the airport is at sealevel. That would be fast. |
Approaching the runway from this altitude, the Space Shuttle has a 22º
glide slope and a rate of descent approaching 22,000 feet per minute. Shuttle Training Aircraft (STA) are Gulfstream II business jets modified to simulate the landing characteristics of the Space Shuttle and used to train astronauts. In order to approximate the high descent rate of the Shuttle, the Gulfstreams pitch nose down into a 20° glideslope with the main landing gear down and thrust reversers deployed. This configuration creates very high drag and gives the STA a rate of descent around 14,000 feet per minute (4,265 m/min) while maintaining a 300 knot dive. Now that's getting down fast! -- Gene Seibel Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html Because we fly, we envy no one. |
If I need to get on the ground that fast.. screw the "pattern" and taxi
time.. The descent will be planned to have me on final and "configured" for landing.. I'll stop on the runway or turn off and shut down.. the trucks can meet me there... screw "taxi"... BTDT BT "Doug" wrote in message ups.com... If you are directly over the airport you can land at, then follow the emergency decent procedures for that plane (and they differ from plane to plane) and come down about 2000 fpm (I really don't know, and it would depend on the plane), but lets use that figure. Then it would take 21 1/2 minutes to get down and maybe 1 1/2 minutes in the pattern and 1 minute of taxi, so that is 23 minutes, assuming the airport is at sealevel. That would be fast. |
Most jets can descend over 10,000fpm. Getting down is not a problem.
Mike MU-2 "David Lesher" wrote in message ... An OT query for folks here. While discussing things that can happen between the jetways, I posited that it's a really bad to be aloft in Big Iron in a medical emergency, etc. -- based on how long it takes to get on the ground. That brings up the question of how long that time really is.... So: If you are at cruise in Boeing's finest at FL430 & declare an emergency; how fast CAN you be down and stopped? (Or Airbus, for that matter....) Assuming ATC can clear a lane, I assume it's a function of how steep a decent you can use without exceeding the max IAS. What are the limits on speed brakes, dropping gear, etc. to dirty things ups? Do you slow to gear-down speed, drop them, then nose over? Or is the higher speed possible w/ gearup better? -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Ah, ok. well at 10,000 fpm, wow can that really be? It would be 4 1/2
minutes (rounding a bit), still about 1 1/2 minutes "in the pattern" (you need some time to level out, slow down and line up) and 1 minute to taxi, giving 6 minutes. That would be REALLY fast! |
"Doug" wrote in message oups.com... Ah, ok. well at 10,000 fpm, wow can that really be? It would be 4 1/2 minutes (rounding a bit), still about 1 1/2 minutes "in the pattern" (you need some time to level out, slow down and line up) and 1 minute to taxi, giving 6 minutes. That would be REALLY fast! Yup, 10,000fpm is 100kts *down*. I think a lot of jets will do *well* over 10,000fpm. My MU-2 will do almost 6,000fpm in a straight, clean, power off descent (no bank) and 10,000fpm in a slip. Keep in mind that many jets can *climb* 5,000fpm when lightly loaded. Mike MU-2 |
"Mike Rapoport" wrote in message k.net... Getting down is not a problem. Mike MU-2 You're right, hence aviation's perfect record of never leaving one up there. |
| Thread Tools | |
| Display Modes | |
| 182RG question | Paul Anton | Owning | 11 | May 16th 05 10:45 PM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| Question for CFIs | Casey Wilson | Piloting | 11 | February 24th 05 11:29 PM |
| Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 06:09 AM |
| Defining Composites (long) | B Lacovara | Soaring | 1 | September 13th 03 09:04 PM |
