Another Cirrus Down
Old December 17th 05, 05:23 PM posted to rec.aviation.student,rec.aviation.piloting
Default Another Cirrus Down
Interestingly CAP just received a memo from Cirrus warning us about the
parachute system and the airbag system. Apparently both become very
dangerous items to a recovery team. They said recovery teams should
**NOT** approach the aircraft until contacting Cirrus if at all
possible. Apparently there is concern that the chute can go off hours
after the accident or that the airbags can explode in front of rescue
teams.
-Robert
Old December 17th 05, 08:25 PM posted to rec.aviation.student,rec.aviation.piloting
teams.
-Robert
That is comforting. You crash in a Cirrus but sustain
life-threatening injuries. So no one can assist until Cirrus is
contacted. So they wait a safe distance from the aircraft until you
die.
Ron Lee
Old December 17th 05, 09:29 PM posted to rec.aviation.student,rec.aviation.piloting
The key phrase is probably "...if at all possible" (that's my
rephrasing, if you are interested I can get the actual memo). However,
your concern is valid. The guys who show up to get you out of the plane
will probably be a CAP ground team. The level of personal risk a
volunteer is willing to accept to pull your bottom out of the aircraft
may vary wildly. However, from my 1 year in CAP this doesn't often seem
to be an issue. When you flight a down plane people are usually either
up and walking around or long gone. This is probably because it takes
so much longer for rescue to reach airplanes vs. cars on the freeway.
-Robert
Old December 18th 05, 07:08 PM posted to rec.aviation.student,rec.aviation.piloting
die.
I have a friend who is a sergeant with the NY State Police. Three and a
half years ago he was the first responder to the fatal Cirrus spin crash
here in Central NY.
He told me was that the police and rescue squad were all warned to remain
clear of the aircraft because of the explosive device used to launch the
parachute. He also added that it was obvious from the state of the bodies
that they were not there to save the pilots lives.
Peter
Old December 19th 05, 02:05 AM posted to rec.aviation.student,rec.aviation.piloting
I am not sure I would willingly fly around with this much life
endangering explosive products in the baggage compartment of my
Warrior....
And in an aircraft that was not engineered to willingly assist the
pilot to maintain, recover to, and sustain controlled flight..
Hmmmmmm...
But, alas, I am also having difficulty in understanding why Garmin
would install magnets in their remote GPS antenna that commonly is
placed on the cowl/glareshield of of what is usually an ALUMINUM or
COMPOSITE aircraft.
Must be getting old, I'm having trouble understanding some things..
Dave
..On Sun, 18 Dec 2005 14:08:02 -0500, "Peter R."
die.
here in Central NY.
Old December 19th 05, 03:56 AM posted to rec.aviation.student,rec.aviation.piloting
Warrior....
When fuel tanks are less than full, one may have an explosive air/fuel
vapor mixture in them. And post-crash fires are sufficiently common that
I'm not sure why a ballistic chute system is considered any more dangerous
than many dozens of pounds of highly flammable liquid. Why would one
consider an undeployed BRS more dangerous than a fuel system on a crashed
plane?
Me too. :-)
Old December 19th 05, 06:35 AM posted to rec.aviation.student,rec.aviation.piloting
On Mon, 19 Dec 2005 03:56:14 -0000, Jim Logajan
Warrior....
That's *may* have, but under normal circumstances I'd expect the
mixture to be above the UEL.
Post crash fires and particularly the spectacular ones are usually
from ruptured tanks.
plane?
The fuel can leak away and vaporize so if there is no immediate fire
there is unlikely to be one. OTOH a primed BRS is primed until
disabled.
To me, it wouldn't make a bit of difference between the two.
If the paths taken where the lanyards are in the fuselage and wings
were marked out they could have avoid areas.
As far as airbags, the system should be capable of being disarmed
easily. If not, it needs fixing.
OTOH It makes me no more nervous to fly planes with out a BRS than it
does with..
www.rogerhalstead.com
Me too. :-)
Old December 19th 05, 10:00 AM posted to rec.aviation.student,rec.aviation.piloting
Jim,
Why would one
plane?
Because in the former case, it is much clearer who to sue in a frivolous law
suit.
Thomas Borchert (EDDH)
Old December 19th 05, 04:59 AM posted to rec.aviation.student,rec.aviation.piloting
"Dave" wrote\
I'm not sure if that is the whole picture. The Cirrus was not certified for
spin resistance and recovery because it would have been so expensive to do
so, up to the FAA's standards. That is not to say that it would not meet
them, if they tried to do so.
Simply put, they took the cheap way out, with the *added* benefit of another
mode of recovery for other types of situations, such as pilot
incompacitation, loss of flight controls, loss of power over inhospitable
terrain...
COMPOSITE aircraft.
Nah, that is called wisdom... I think! g
I predict that Garmin will finally give in and make a new type of antenna.
(I hope)
Jim in NC
Old December 20th 05, 04:10 AM posted to rec.aviation.student,rec.aviation.piloting
Apparently the pressure is building...
It is an expensive unit, and some people are getting upset..
The magnets are very difficult to remove, Garmen has made it
abundantly clear that this will void the warranty, and have no
interest in exchanging it for one without magnets, which of course
they don't make ..
Or something like that...
WHAT were they thinking? (or were they) Surprising from a company with
long experience in aviation GPS units....
Dave
On Sun, 18 Dec 2005 23:59:14 -0500, "Morgans"
(I hope)
Cirrus demo Dan Luke Piloting 12 December 4th 05 05:26 AM
New G-1000 182 & Cirrus SR-22 GTS Dan Luke Owning 22 June 27th 05 07:18 PM
Iced up Cirrus crashes Dan Luke Piloting 136 February 16th 05 07:39 PM
Cirrus SR22 Purchase advice needed. C J Campbell Piloting 122 May 10th 04 11:30 PM
