Cirrus demo
Old December 2nd 05, 10:07 PM posted to rec.aviation.piloting
Default Cirrus demo
My entry was one of those drawn at OSH for a 2-hour checkout in an SR-22, and
we finally coordinated everything and made the flight yesterday. The
following are my impressions of the aircraft:
Getting aboard is easier than in most low-wingers because of the two large
doors. The seats are firm and comfortable and the front cabin is roomier
than a Bonanza.
A hot start was easy with the experienced Cirrus demo pilot to help. Taxiing
is simple by using differential braking, but I would prefer a steerable nose
gear--crosswinds require riding one of the brakes to go straight. The rudder
and brake pedal forces are heavier than my Cutlass RG.
The PFD and MFD were a bit bewildering at first simply because I hadn't
learned the scan yet. There are electronic checklists on the MFD that are
easy to use, and getting the airplane ready for takeoff was simple.
We aborted the takeoff roll because of an open door warning. It doesn't tell
you which one and doesn't annunciate until you advance the throttle for
takeoff, so we had to do the drill twice before we had the proper door
secured. Once we'd sorted that out, I shoved the throttle full forward and
waited for 70 knots rotation speed. This took rather longer to arrive than I
expected; the SR-22 is not a short field airplane. After rotation, I pitched
to +12 degrees for Vy and retracted the 50% takeoff flaps at 80 knots IAS.
Climbout is pretty brisk for someone accustomed to a 180 hp 172RG--about 1200
fpm, IIRC. The ailerons are very crisp and responsive, but I found I needed
to re-trim them at various times, something I'm not used to. The electronic
trim seemed to work well, contrary to reports I've read of its being over
sensitive. The airplane was out of yaw trim and I had to hold right rudder
the whole flight, which was annoying. Yaw trim can only be adjusted on the
ground.
As we climbed to 4500', we spent a while setting up the autopilot for rate of
climb and altitude preselect. It was at this point that I realized the
Cirrus is a systems management airplane. There is an awful lot going on,
it's happening fairly quickly, and the slippery Cirrus can get badly out of
shape on you in a hurry. In my airplane, the autopilot is a good helper. In
the Cirrus, it's an indispensable crew member for single-pilot IFR;
definitely a no-go item if it's inop. Furthermore, the pilot must be razor
sharp on pushing all those buttons and twisting all those knobs if he plans
on making approaches in IMC or he will quickly find himself miles behind the
situation when crunch time comes. This is not an airplane that confers extra
safety by virtue of its advanced systems--rather the reverse, IMO.
At 80% power, 65 deg. ROP, the SR-22 made 178 KTAS at 4500 feet. Wow! That's
great...uh-oh, look at the fuel burn: 19.7 GPH. Woof! Glad it was on
Klapmeier's credit card! Coming back, we ran 65% power, LOP and got 158
KTAS at 5500 feet and burned 11.8 GPH.
We vectored ourselves for an ILS at Hammond, LA and I found the airplane very
easy to manage on my first attempt at a hand-flown approach. The PFD has
some nice cues for the pilot to keep himself on the localizer and the Cirrus
came down the glideslope quite nicely. Of course, it would have been even
nicer if I'd let George do it, as I'm sure I would in IMC.
In the pattern, the airplane is easy to manage. The Cirrus guy had me fly
100-90-80 on downwind-base-final. The roundout altitude takes some getting
used to. I tended to round out high my first couple of times. After that, I
found the Cirrus quite easy to land.
I enjoyed the SR-22, but I think I will decline the opportunity to buy an
airplane that costs twice as much as my house. When I get '87D sold, I'll be
in the market for a nice used Bonanza or 210.
Dan
C-172RG at BFM
Old December 2nd 05, 10:46 PM posted to rec.aviation.piloting
Default Cirrus demo
("Dan Luke" wrote)
and we finally coordinated everything and made the flight yesterday. The
Nice report. I'd like to see more of that kind of writing in the Flying
mags.
More real, less gush.
Montblack
Old December 2nd 05, 10:48 PM posted to rec.aviation.piloting
Default Cirrus demo
"Dan Luke" wrote in message
than a Bonanza.
Taxiing is simple by using differential braking, but I would prefer a
steerable nose gear--crosswinds require riding one of the brakes to go
straight. The rudder and brake pedal forces are heavier than my Cutlass
RG.
tell you which one and doesn't annunciate until you advance the throttle
for takeoff, so we had to do the drill twice before we had the proper door
and waited for 70 knots rotation speed. This took rather longer to arrive
than I expected; the SR-22 is not a short field airplane. After rotation,
I pitched to +12 degrees for Vy and retracted the 50% takeoff flaps at 80
knots IAS.
1200 fpm, IIRC. The ailerons are very crisp and responsive, but I found I
needed to re-trim them at various times, something I'm not used to. The
electronic trim seemed to work well, contrary to reports I've read of its
being over sensitive. The airplane was out of yaw trim and I had to hold
right rudder the whole flight, which was annoying. Yaw trim can only be
adjusted on the ground.
of climb and altitude preselect. It was at this point that I realized the
of shape on you in a hurry. In my airplane, the autopilot is a good
helper. In the Cirrus, it's an indispensable crew member for single-pilot
IFR; definitely a no-go item if it's inop. Furthermore, the pilot must be
razor sharp on pushing all those buttons and twisting all those knobs if
he plans on making approaches in IMC or he will quickly find himself miles
behind the situation when crunch time comes. This is not an airplane that
confers extra safety by virtue of its advanced systems--rather the
reverse, IMO.
That's great...uh-oh, look at the fuel burn: 19.7 GPH. Woof! Glad it
was on Klapmeier's credit card! Coming back, we ran 65% power, LOP and
got 158 KTAS at 5500 feet and burned 11.8 GPH.
very easy to manage on my first attempt at a hand-flown approach. The PFD
has some nice cues for the pilot to keep himself on the localizer and the
Cirrus came down the glideslope quite nicely. Of course, it would have
been even nicer if I'd let George do it, as I'm sure I would in IMC.
getting used to. I tended to round out high my first couple of times.
After that, I found the Cirrus quite easy to land.
be in the market for a nice used Bonanza or 210.
Dan
C-172RG at BFM
Cool deal, always fun when it's on the other guys dime!
DW
Old December 2nd 05, 11:21 PM posted to rec.aviation.piloting
Default Cirrus demo
Recently, Dan Luke posted:
SR-22, and we finally coordinated everything and made the flight
yesterday. The following are my impressions of the aircraft:
Nice write-up! The SR-22 is one of those planes that I'd like to get into
one of these days, but like you, the price would not make it a practical
first-choice for a purchase.
Thanks!
Neil
Old December 3rd 05, 12:49 AM posted to rec.aviation.piloting
Default Cirrus demo
I've been flying SR-22s exclusively over the 18 months. I used to fly
Cessnas (172 and 182) before that.
Between flying the Cessnas and the Cirrus, I took a break from flying
for many years.
Back in the saddle, it took me a little while to get used to the SR-22,
but much of that was just knocking off rust in my technique and
proficiency. I adapted to the SR-22 relatively quickly (greased
landings after the first 2 or 3 bounces). It took me a little while
longer to get used to programming the Garmins and using the PFD in IMC.
My family takes comfort in knowing that if I pass out during a flight,
they just have to find flat ground, retard throttle and stick, and
deploy the CAPS 'chute below 130 knots.
Now, I would go back to the six-pack steam gages (especially
vacuum-driven) and they would not go back to a plane without a 'chute.
Old December 3rd 05, 01:59 AM posted to rec.aviation.piloting
Default Cirrus demo
What speed did you fly the ILS? Power? Configuration?
Thanks, Dan! You have re-affirmed my affection for the 182, 210 and
Bonanza. Just think how many more airports are available to you with
these airplanes.
Old December 3rd 05, 02:25 AM posted to rec.aviation.piloting
Default Cirrus demo
"rps" wrote
Now, I would (???) go back to the six-pack steam gages
I assume you intended to put "not" in there?
Old December 3rd 05, 02:42 AM posted to rec.aviation.piloting
Default Cirrus demo
About 100 KIAS, 50% flaps. Don't remember the power setting for sure,
but I think it was 11".
Old December 3rd 05, 06:45 PM posted to rec.aviation.piloting
Default Cirrus demo
"john smith" wrote in message
fly
getting
that, I
I'll be
these airplanes.
According to Raytheon and Cirrus the current Bonanza take more runway than
the SR22. According to
http://www.risingup.com/planespecs/i...rplane97.shtml
they both use about the same runway distance
MU-2
Old December 3rd 05, 09:06 PM posted to rec.aviation.piloting
Default Cirrus demo
fly
getting
that, I
I'll be
these airplanes.
You need real world numbers. My S35, at 3500 MSL and 850 under gross
which is a typical weight when I'm just farting around the local area,
needs 550 feet to get airborne and the same 550 feet to get stopped.
What does the Cirrus do at that weight? The real deal killer is having
to stay on pavement. My plane was designed for rough strips. The
Cirrus falls apart if the pavement isn't perfectly smooth.
Cirrus SR22 demo flight [email protected] Piloting 44 May 6th 05 04:47 PM
