IO540 baffle repair
Old January 9th 06, 03:23 PM posted to rec.aviation.owning
Default IO540 baffle repair
Last week I found the baffle on our left engine's #6 cylinder had broken the
bracket off the bottom of the baffle. The bracket holds a long skinny
tension/stabilizer rod between the #6 cylinder baffle and the #2 cylinder
baffle.
From what I can tell, the bracket simply needs to be rivited back on to the
baffle, however the baffle will have to be removed to accomplish this. I
have yet to pull the top cowl so I can actually see how the baffle is
attached.
Does anybody have any experience removing this particular baffle? I'm sure
it would have to be removed before the #6 cylinder could be pulled.
Any thoughts are appreciated.
Old January 9th 06, 08:07 PM posted to rec.aviation.owning
Get somebody who does a lot of his own maintenance to help you - and
who has some rivets, aluminum, and tools... This is not rocket
science... Easily done with common sense and a little show-n-tell from
others...
denny
Old January 9th 06, 08:24 PM posted to rec.aviation.owning
Just what I wanted to hear.
Thanks Denny.
"Denny" wrote in message
others...
denny
De-ice boot repair gbessert Owning 3 August 29th 17 07:30 PM
Dittel Radio Repair [email protected] Soaring 4 July 22nd 05 12:02 PM
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 01:41 PM
Advised on FAA Repair Station outside USA tbm700 Owning 0 September 23rd 04 05:50 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
