Bi-wing glider
Old February 21st 06, 11:43 AM posted to rec.aviation.soaring
Default Bi-wing glider
A thought came to me the other day...
Now, I have never seen a bi-wing glider, but was thinking,
could a bi-wing glider of, say 15m wingspan, effectively
have 30m performace?
This is probably a stupid uneducated question, and
I would imagine that it hasnt been done because it
wouldnt work! But its certainly something I am interested
in.
Think of it...a bi-wing ETA giving a total of 60m performance!
JR
Old February 21st 06, 12:45 PM posted to rec.aviation.soaring
The main idea of long wings is to reduce the relative part of the wingtip
vortexes in the total amount of the drag.
Having 4 vortexes instead of 2 certainly doesn't help.
"Jono Richards" wrote in
message ...
in.
JR
Old February 21st 06, 04:52 PM posted to rec.aviation.soaring
Ok, what if one of the wings is a canard? If the elevator pushes down to
support the nose, and a canard lifts, doesn't that make a canard more
efficient?
Al
"Bert Willing" wrote in message
message ...
in.
JR
Old February 21st 06, 06:14 PM posted to rec.aviation.soaring
efficient?
No. Take a look at the success of Rutan's Solitaire.
The disadvantages with a canard or a tandem wing plane is that it is
hard to use flaps, and to keep the plane pitch stable you end up with a
plane that won't develop the same maximum total lift coefficient as a
"normal" plane because you can never use the aft wing to it's full
potential. This means that you end up having a higher minimum speed
for a given wing area or need more wing for a given minimum speed.
What all this means is that the speed range for efficient operation
will be less than that of a comparable "normal" plane.
You can tune the plane to be efficient at one speed by matching the
airfoils and relative areas and this is how some of the canard
homebuilts manage to show such good cruise performance. But they all
suffer from high landing speeds.
About the only way I see to improve on the standard glider - might - be
to develop a flying wing with some kind of weight shift to increase
it's speed range.
The canard/tandem wing planform does have some advantages for powered
planes but even there I've decided that a negative stagger biplane with
a conventional empenage (Durand Mk V is an example) is more efficient
than a pure tandem wing or canard ..................... and why my Q-2
will fly with a V-tail and flaps if I ever decide to finish it.
Just my opinion
Leon McAtee
Old February 21st 06, 08:47 PM posted to rec.aviation.soaring
Thanks, very informative. Al
efficient?
it's speed range.
Just my opinion
Leon McAtee
Old February 21st 06, 12:46 PM posted to rec.aviation.soaring
in.
Short answer: no.
The F1H competition model glider class has a maximum total *projected*
wing area limit, so some years back an ingenious chap built a bi-plane
version with no stagger so the projected area was the same as for a
monoplane but with halved wing loading. He omitted interplane struts to
minimize drag, but the model flew better with one wing removed.
The reason was that you get a lot of interference drag between the
wings. His interplane spacing was about 1.5 wing chords. Theoretical
calculations later showed that he should have used a spacing of at least
5 chords to avoid interference gap.
A sailplane with a 0.7m average chord would need an interplane gap of
3.5m and you'd still have a lot of drag from interplane struts. You'd
need step-ladders or a fork lift to rig it.
However, it would win the Ugly Trophy hands down.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old February 21st 06, 02:08 PM posted to rec.aviation.soaring
"I have never seen a bi-wing glider"
Orville and Wilbur used to fly them.
Colin
Old February 21st 06, 03:34 PM posted to rec.aviation.soaring
At 14:12 21 February 2006, Colin Lamb wrote:
'I have never seen a bi-wing glider'
Colin
Colin,
Good point hadnt thought of that! Were those not kites,
rather than gliders? Or maybe I should read my history
books again...
Right so there is no benefit in havin two wings than
one? even if staggered to reduce the interference from
each?
As regards to using a fork lift to rig, no i am sure
it would be far from practical, but then again, what
would some people do in the strive for performance...!?
JR
Old February 21st 06, 04:13 PM posted to rec.aviation.soaring
message ...
Colin
Colin,
books again...
each?
JR
You probably should go back and read your history again.
The Wright's 1902 glider is probably the most important aircraft in the
history of aviation.
It's the aircraft all their patents were based on.
Tim Ward
Old February 22nd 06, 03:39 AM posted to rec.aviation.soaring
Tim Ward
Don't forget the Wright 1911 biplane glider. On 24 Oct 1911, Orville
soared it for 9 minutes 45 seconds, a world record that stood for 10
years.
http://worlddmc.ohiolink.edu/History...arch status=0
John
48.4 hours !? [email protected] Soaring 49 April 28th 05 12:12 AM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
Unintentional fully-developed spins... Marc Ramsey Soaring 62 February 12th 04 05:52 PM
Latest Newsletter Pipistrel Motorgliders Michael Coates Soaring 20 September 19th 03 01:25 AM
