48.4 hours !?
Old April 21st 05, 04:54 PM
Default 48.4 hours !?
NTSB Identification: LAX05LA131
14 CFR Part 91: General Aviation
Accident occurred Wednesday, April 06, 2005 in Mokuleia, HI
Aircraft: Schweizer SGS 2-32, registration: N693U
Injuries: 1 Fatal, 2 Minor.
This is preliminary information, subject to change, and may contain
errors. Any errors in this report will be corrected when the final
report has been completed.
On April 6, 2005, at 1300 Hawaiian standard time, a Schweizer SGS 2-32
glider, N693U, impacted mountainous terrain 0.4 miles south of the
Dillingham Airfield, Mokuleia, Hawaii. The commercial glider pilot was
fatally injured and the two passengers sustained minor injuries. The
glider sustained substantial damaged. Sailplane Ride Adventures, Inc.,
owned and operated the glider under the provisions of 14 CFR Part 91 as
a scenic sailplane ride. Visual meteorological conditions prevailed,
and a flight plan had not been filed for the local flight. The
20-minute scenic flight was in the air approximately 17 minutes.
According to an interview summary provided by the Federal Aviation
Administration (FAA), the passengers reported that they were circling
around a hill and thought that they were returning to the airport. The
glider crossed over a ridge to a valley to look at a waterfall. The
glider turned left then right in a gentle but accelerating manner. The
glider also pitched up and down, and the passengers felt like they were
falling. The pilot announced that they were "going in." The glider
impacted trees and terrain, and came to rest upside down.
Another witness, who was a glider pilot flying at the time of the
accident, observed the accident glider behind her, heading east
approximately 400-500 feet above the ridge. She checked back on the
glider's position relative to hers and noticed the glider "turn right
(toward the ridge) and its nose come up slightly." The glider turned
"approximately 45 degrees to the right, then turned back to the left
and immediately entered a spin to the left." The witness reported that
the glider rotated twice before it entered a spin to the right. The
witness then lost sight of the glider behind trees before it completed
a rotation to the right.
The accident site was at 21 degrees 34 minutes 21 seconds north
latitude and 158 degrees 12 minutes and 54 seconds west longitude at an
elevation of approximately 1,000 feet msl. The glider came to rest on
the east side of a gulch that cut through the east-west running
ridgeline situated to the south of Dillingham Airfield. Review of
photographs of the accident site revealed that the glider fuselage came
to rest inverted with the left and right inboard wings intact. The left
and right outboard wing sections were detached; however, the left
outboard wing section remained attached to the main wreckage via flight
control cables. The right outboard wing section came to rest
approximately 40 feet from the main wreckage at the base of freshly
broken trees. The wing leading edges displayed circular indentations
similar in size to the diameter of the surrounding trees. The tail
section folded over the belly of the airplane.
The glider was recovered to Dillingham Airfield on April 8, 2005.
According to the FAA inspectors that responded to the accident site,
flight control continuity was confirmed from the cockpit to the flight
control surfaces.
The pilot received his student pilot certificate on March 16, 2005. On
March 24, 2005, he received his private pilot certificate with a glider
rating. On March 26, 2005, he obtained his commercial pilot certificate
with a glider rating. According to the pilot's logbook, as of April 5,
2005 (the day before the accident), he accumulated a total of 48.4
hours of flight time, of which 31.2 hours were as pilot-in-command.
Old April 21st 05, 05:38 PM
John Doe
31.2 hours P1? To me that seems a little low? What
are the US requirements for a commercial rating? Here
in the UK you need 50 and silver before you can get
a Basic Instructor rating (To give first lessons, but
not past turning, so I think about equivalent..).
Is this a normal requirement or is this exceptional?
Jamie
HI
and may contain
when the final
Schweizer SGS 2-32
south of the
glider pilot was
injuries. The
Adventures, Inc.,
prevailed,
flight. The
17 minutes.
Aviation
they were circling
to the airport. The
a waterfall. The
manner. The
felt like they were
falling. The pilot announced that they were 'going
in.' The glider
down.
time of the
heading east
back on the
glider 'turn right
(toward the ridge) and its nose come up slightly.'
The glider turned
'approximately 45 degrees to the right, then turned
back to the left
and immediately entered a spin to the left.' The witness
reported that
the right. The
before it completed
north
came to rest on
running
Review of
intact. The left
the left
wreckage via flight
to rest
base of freshly
indentations
trees. The tail
April 8, 2005.
accident site,
to the flight
control surfaces.
March 16, 2005. On
with a glider
pilot certificate
as of April 5,
a total of 48.4
Old April 21st 05, 06:34 PM
ttaylor at cc.usu.edu
The USA requirements are way too low. No real soaring experience
required. I think that all ratings should be required to demonstrate
real soaring skills, not just flying skills. This is about the third
accident in Hawaii with similar stall spin characteristics into the
trees.
Commercial Pilot-Glider: FAR 61.121-61.141
Age requirement: at least 18 years of age.
* Be able to read, speak, write, and understand English.
* Hold at least a private pilot certificate (for heavier-than-air
aircraft.)
For initial certificate issuance, pass a knowledge test (FAR
61.125) and practical test (61.127). The launch method(s) endorsed in
the pilot's logbook (61.31(j)) determines in which type of launch(s)
the pilot has demonstrated proficiency.
There are two levels of experience required for issuance of a
commercial certificate;
1.At least 25 hours as a pilot in gliders, including;
1. 100 flights in gliders as pilot in command; and,
2. 3 hours of flight training or 10 training flights in
gliders; and,
3. 2 hours of solo flight to include not less than 10
solo flights; and,
4. 3 training flights in preparation for the flight
test.
Old April 21st 05, 06:44 PM
Ramy
One word to describe this: ABSURD.
Thinking of those unsuspecting passengers who put their lives in the
hands of someone they believe is very experienced.
Ramy
trees.
aircraft.)
in
gliders; and,
solo flights; and,
test.
Old April 21st 05, 06:48 PM
Ramy
As usual, the NTSB report is useless. Doesn't even attempt to analyze
the cause for the accident.
Old April 21st 05, 07:25 PM
Don Johnstone
When all else fails blame the pilot, especially a dead
one, he ain't going to argue is he. You may of course
be right but just think about the assumption you have
all made. Would you want someone to think that of you?
I think you might have the common decency to wait for
the result of the official enquiry before sentence.
Shame on you all.
lives in the
Ramy
experience
to demonstrate
is about the third
into the
trees.
English.
heavier-than-air
aircraft.)
test (FAR
endorsed in
type of launch(s)
of a
including;
in command; and,
training flights
in
gliders; and,
not less than 10
solo flights; and,
for the flight
test.
Old April 21st 05, 07:38 PM
Stefan
If I had made a fatal error: Yes. Yes, I would want people to not only
think, but talk about my error and learn something.
But I agree, by now it's only speculation. However, spinning into the
ground smells like pilot error.
Stefan
Old April 21st 05, 07:40 PM
Ramy
Who blames the pilot? The FAA or the commercial opperation is to be
blamed!
Do you think the passengers would have take the ride if they knew their
pilot soloed just 3 weeks ago? Would you send a loved one to take a
ride with a pilot who just soloed?
And which other official inquiry you expect to get? The NTSB report
*is* the official inquiry.
My condolences to the pilot's family and friends.
Ramy
Old April 21st 05, 07:52 PM
5Z
The first paragraph of the NTSB statement:
It will be weeks or months before they produce conclusions. The report
we are seeing is a summary of the facts as they know them at the time
of initial investigation.
Unfortunately, the NTSB generaly only puts out two reports. The
original, usually very sketchy, and the final, factual one. In
between, we just wait.
-Tom
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
