I recently reread Richard Johnson's article, "Sailplane Performance
Flight Test Methods" in the May, 1989 issue of Soaring magazine. In the article Johnson mentions the Deceleration Measurement method of determining a performance polar. It had occured to me a couple of years ago that such a method could be used in conjunction with GPS data as a fairly simple way of measuring glider performance. I envision importing the GPS time, altitude, and position data into a spread sheet application to do the number crunching. Anyone out there ever tried anything like that? Anyone have suggestions or caveats about doing it? Myles Bradley |
![]() wrote in message ups.com... I recently reread Richard Johnson's article, "Sailplane Performance Flight Test Methods" in the May, 1989 issue of Soaring magazine. In the article Johnson mentions the Deceleration Measurement method of determining a performance polar. It had occured to me a couple of years ago that such a method could be used in conjunction with GPS data as a fairly simple way of measuring glider performance. I envision importing the GPS time, altitude, and position data into a spread sheet application to do the number crunching. Anyone out there ever tried anything like that? Anyone have suggestions or caveats about doing it? Myles Bradley I don't know if it has been actually tried but I have heard it discussed several times. If, and it's a big if, you know that the glider can be flown perfectly level as it slows down, then you measure the rate at which airspeed is lost, the whole polar can be computed from a single pass. Back in the 1960's it was proposed to build an "alley" of helium balloons staked out in two parallel rows exactly1000 feet above a dry lake to avoid ground effect. The glider pilot would use the balloons as an eyeball guide in flying a level path. An on-board strip chart recorder would record airspeed against time as it decayed from Vne to stall. I don't think it was ever tried. Obviously, there are considerable problems with this approach not the least is that it will require a dead calm day and very cool hand on the controls. If there is an advantage it is that only one tow is needed and higher performance glider take longer to slow down so resolution improves. I don't see how GPS would help unless, somehow, GPS altitude could be made to provide centimeter level accuracy. Vertical motion in the atmosphere would still skew the results. There is a third potential method with its own difficulties. L/D is the angle between exact level and the free stream flow. If you had an inertial reference unit that could establish exact level and a pitch vane on a long nose probe, the angle of the vane measured against level is the L/D. The problem is that the angles are very small. (40:1 L/D = 1.43 degrees , 60:1 = .0.95 degrees) and small angular errors generate large L/D errors. All considered, the timed descent series method that Dick Johnson uses is the least difficult and if done carefully, produces very good results. Bill Daniels |
![]() "Bill Daniels" bildan@comcast-dot-net wrote in message . .. I don't know if it has been actually tried but I have heard it discussed several times. If, and it's a big if, you know that the glider can be flown perfectly level as it slows down, then you measure the rate at which airspeed is lost, the whole polar can be computed from a single pass. Back in the 1960's it was proposed to build an "alley" of helium balloons staked out in two parallel rows exactly1000 feet above a dry lake to avoid ground effect. The glider pilot would use the balloons as an eyeball guide in flying a level path. An on-board strip chart recorder would record airspeed against time as it decayed from Vne to stall. I don't think it was ever tried. Obviously, there are considerable problems with this approach not the least is that it will require a dead calm day and very cool hand on the controls. If there is an advantage it is that only one tow is needed and higher performance glider take longer to slow down so resolution improves. I don't see how GPS would help unless, somehow, GPS altitude could be made to provide centimeter level accuracy. Vertical motion in the atmosphere would still skew the results. There is a third potential method with its own difficulties. L/D is the angle between exact level and the free stream flow. If you had an inertial reference unit that could establish exact level and a pitch vane on a long nose probe, the angle of the vane measured against level is the L/D. The problem is that the angles are very small. (40:1 L/D = 1.43 degrees , 60:1 = .0.95 degrees) and small angular errors generate large L/D errors. All considered, the timed descent series method that Dick Johnson uses is the least difficult and if done carefully, produces very good results. All this stuff has been used by the Idaflieg in the 80's, and they now work on a differential GPS measurement system. The point with the vane obviously works only if its base is in the free flow, and if it is the base which is levelled horizontally. If the base is connected to the fuselage, it will give you the fuselage pitch and nothing else. The point with all measurements done without a reference glider is that you can't cancel vertical airmass movements. That's ok if you are measuring a 2-33, but on anything like a 40+ ship an airmass movement of a few cm/s will result in substantial differences. An error of 1 cm/s in the sink of a 50:1 ship gives ore takes almost 1 point. A couple of cm/s sink is something you often have associated with high pressure regions over a wide area (that's actually how they function). That is the main reason the Idaflieg measurements are usually trusted far more than Dick's measurement. Dick is putting an enormous effort in getting good results, but he just can go so far. |
I'm looking forward to seeing what else comes from this post.
Can't the pressure altitude recorded in the log file be used? The altitude used doesn't need to be accurate in the absolute sense (does it?); rather just show the accurate altitude delta over the measurement window. On the topic of flight tests, I usually hear crickets when I ask this question, but does anyone know where the Ventus 2 polar came from in the SeeYou database (Tools | Polar)? ~ted/2NO |
At 00:00 28 February 2006, Bill Daniels wrote:
wrote in message oups.com... I recently reread Richard Johnson's article, 'Sailplane Performance Flight Test Methods' in the May, 1989 issue of Soaring magazine. In the article Johnson mentions the Deceleration Measurement method of determining a performance polar. It had occured to me a couple of years ago that such a method could be used in conjunction with GPS data as a fairly simple way of measuring glider performance. I envision importing the GPS time, altitude, and position data into a spread sheet application to do the number crunching. Anyone out there ever tried anything like that? Anyone have suggestions or caveats about doing it? Myles Bradley I don't know if it has been actually tried but I have heard it discussed several times. If, and it's a big if, you know that the glider can be flown perfectly level as it slows down, then you measure the rate at which airspeed is lost, the whole polar can be computed from a single pass. Back in the 1960's it was proposed to build an 'alley' of helium balloons staked out in two parallel rows exactly1000 feet above a dry lake to avoid ground effect. The glider pilot would use the balloons as an eyeball guide in flying a level path. An on-board strip chart recorder would record airspeed against time as it decayed from Vne to stall. I don't think it was ever tried. Obviously, there are considerable problems with this approach not the least is that it will require a dead calm day and very cool hand on the controls. If there is an advantage it is that only one tow is needed and higher performance glider take longer to slow down so resolution improves. I don't see how GPS would help unless, somehow, GPS altitude could be made to provide centimeter level accuracy. Vertical motion in the atmosphere would still skew the results. There is a third potential method with its own difficulties. L/D is the angle between exact level and the free stream flow. If you had an inertial reference unit that could establish exact level and a pitch vane on a long nose probe, the angle of the vane measured against level is the L/D. The problem is that the angles are very small. (40:1 L/D = 1.43 degrees , 60:1 = .0.95 degrees) and small angular errors generate large L/D errors. All considered, the timed descent series method that Dick Johnson uses is the least difficult and if done carefully, produces very good results. Bill Daniels I have calculated speed to fly/flap postion for my DG808B by running a pre-planned gps course of 5 mile per setting in a straight line and calculating L/D for each speed from the data log. While the actual L/D may be off slightly due to wind the relative values should be accurate. This provides the best speed to fly each flap position. I have also run pure L/D tests also using a pre-planned gps course over a 15 mile course in both directions to cancel out wind effect which is what is loaded into my flight computer polar. |
CRS: V-22 Osprey Tilt-Rotor Aircraft | Mike | Naval Aviation | 0 | October 14th 05 08:14 PM |
48.4 hours !? | [email protected] | Soaring | 49 | April 28th 05 12:12 AM |
Power Commercial to Glider Commercial | Mitty | Soaring | 24 | March 15th 05 03:41 PM |
Seeking Partners for Minden Based Glider | Don Johnson | Soaring | 0 | August 31st 03 07:20 PM |
Announce/USA: FAA Glider Flying Handbook / Bob Wander | SoarBooks | Soaring | 0 | August 11th 03 03:55 PM |
