Q: repair shop in Southern CA or AZ?
Old March 3rd 06, 06:17 AM posted to rec.aviation.soaring
Default Q: repair shop in Southern CA or AZ?
Our club has a Grob 103 Twin Astir which will require the elevator control
horn to be replaced per the recent AD. We're looking for a shop to do both
the mechanical work and the composite work. We've found a couple of shops in
northern California, but are looking for someone closer to home just to make
the transport easier. Can anyone direct us to some repair companies in
southern California or Arizona?
Thanks.
Roger
Old March 3rd 06, 06:18 AM posted to rec.aviation.soaring
Thanks.
Roger
None in So Cal so far as I know.
Old March 3rd 06, 07:06 AM posted to rec.aviation.soaring
There's a guy named Robie Grove at Gillespie Field (near San Diego)
who sometimes does composite/mechanical work on gliders.
Old March 3rd 06, 03:38 PM posted to rec.aviation.soaring
There are currently no shops in Arizona - folks from the Phoenix area
usually end up going to our nearest outfit in New Mexico.
Sorry!
Mike
Old March 3rd 06, 04:09 PM posted to rec.aviation.soaring
Caracole doesn't do composite repairs and the shop at California City that
did is gone. Bill Prokes (Tile, Signs and Graphics in Tempe, AZ, (480)
967-6029) does first-class work but is also far away. Most repair work from
Cal City goes to Williams or Minden.
Ray Warshaw
1LK
Also, have you tried Caracole and Crystal? they have a mechanic
there... but I don't know about an A.I.
Mike Malis
Old March 3rd 06, 04:16 PM posted to rec.aviation.soaring
Raphael Warshaw wrote:
Most repair work from Cal City goes to Williams or Minden.
Who is doing composite work at Minden these days?
Marc
Old March 3rd 06, 06:27 PM posted to rec.aviation.soaring
If you don't have glass work there's a good chance that Jeremy at Turf
Soaring can do it. He's the A&P who does the glider maintenance for the
commercial operation there. You may want to give Turf a call.
-ted/2NO
Old March 4th 06, 04:34 AM posted to rec.aviation.soaring
I believe glass work is required to bond the replacement control arm into
the elevator
BT
-ted/2NO
Old March 4th 06, 09:40 AM posted to rec.aviation.soaring
Rex at Williams has done the mod on at least 1 Grob.
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 01:41 PM
Running a repair shop Greg Esres Owning 15 May 24th 04 05:06 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
Anyone in France or Germany, nearest repair shop to Limoges Bellegarde,contact info goneill Soaring 1 October 28th 03 04:03 PM
