VNO is Maximum Structural Cruising Speed per definition in CFR FAR Part
1. If you were to ask what is VNO? Why do some Pilots constantly believe its Normal Operation Speed. The Green arc is the normal operation. The yellow arc is cautionary range. The white arc is the range in which we can use flaps. The top of the white is VFE. The bottom of the white arc is VS0. Just like the Bottom of the green is VS1. Of course VNE never-exceed speed is the tiny red arc and we shouldn't go there! So tell me what is the definition of VNO? Cjamairway |
VA means design maneuvering speed.
VB means design speed for maximum gust intensity. VC means design cruising speed. VD means design diving speed. VDF/MDF means demonstrated flight diving speed. VEF means the speed at which the critical engine is assumed to fail during takeoff. VF means design flap speed. VFC/MFC means maximum speed for stability characteristics. VFE means maximum flap extended speed. VFTO means final takeoff speed. VH means maximum speed in level flight with maximum continuous power. VLE means maximum landing gear extended speed. VLO means maximum landing gear operating speed. VLOF means lift-off speed. VMC means minimum control speed with the critical engine inoperative. VMO/MMO means maximum operating limit speed. VMU means minimum unstick speed. VNE means never-exceed speed. VNO means maximum structural cruising speed. VR means rotation speed. VREF means reference landing speed. VS means the stalling speed or the minimum steady flight speed at which the airplane is controllable. VS0 means the stalling speed or the minimum steady flight speed in the landing configuration. VS1 means the stalling speed or the minimum steady flight speed obtained in a specific configuration. VSR means reference stall speed. VSRO means reference stall speed in the landing configuration. VSR1 means reference stall speed in a specific configuration. VSW means speed at which onset of natural or artificial stall warning occurs. VTOSS means takeoff safety speed for Category A rotorcraft. VX means speed for best angle of climb. VY means speed for best rate of climb. V1 means the maximum speed in the takeoff at which the pilot must take the first action (e.g., apply brakes, reduce thrust, deploy speed brakes) to stop the airplane within the accelerate-stop distance. V1 also means the minimum speed in the takeoff, following a failure of the critical engine at VEF, at which the pilot can continue the takeoff and achieve the required height above the takeoff surface within the takeoff distance. V2 means takeoff safety speed. V2min means minimum takeoff safety speed. wrote in message oups.com... | VNO is Maximum Structural Cruising Speed per definition in CFR FAR Part | 1. If you were to ask what is VNO? Why do some Pilots constantly | believe its Normal Operation Speed. The Green arc is the normal | operation. The yellow arc is cautionary range. The white arc is the | range in which we can use flaps. The top of the white is VFE. The | bottom of the white arc is VS0. Just like the Bottom of the green is | VS1. Of course VNE never-exceed speed is the tiny red arc and we | shouldn't go there! | | So tell me what is the definition of VNO? | | Cjamairway | |
Thanks... now riddle me this. Why do they call it VNO and not VSC? The others have initials that recall their definitions, why not this? Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
There are a lot of things in aviation that go against our normal
instincts or reactions. Like when you first performed an emergency procedure your instructor reduced the power to idle. I bet your first reaction was to lower the nose. Now you know to trade potential engergy for kinetic and raise the nose, climb to bleed the airspeed off to catch your best glide speed. Its a trade off. So here is what happens with VNO. People like acronyms. So those who were taught that VNO is Normal operation speed needed words that matched VNO. For those of us who are anal retentive and yes I am one of those people because I must follow strict interpretation of regulations because I am required to do so, we'll always know that VNO is Maximum structural cruising speed. Look in FAR part 1 under definitions. |
"Neil Gould" wrote in message
m... So... your response to Jose's riddle is that "it's VNO because they called it VNO"? I would think that the "anal retentive" response would actually supply an answer to how that acronym was derived, since that was the question that was asked. We all know that we just have to memorize those things that make no logical sense. ;-) If there is no practical explanation, then it could be argued that it's just "trivia." Marco Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Please indulge me here..
VA is where military vets get their benefits from, also a southern state VC were the guys in the black pajamas carrying Kalashnikovs VD is what you end up with after buying that skanky chick too many drinks VH was a huge rock group from the 80's VMU is the speed you rotate at to avoid the cow on the runway V2 was a German rocket from WW2 I feel better now... Long day at work ya know... |
VA is where military vets get their benefits from, also a southern state VC were the guys in the black pajamas carrying Kalashnikovs VD is what you end up with after buying that skanky chick too many drinks VH was a huge rock group from the 80's VMU is the speed you rotate at to avoid the cow on the runway V2 was a German rocket from WW2 .... and V8 is what you drink before a flight, when you can't have 151. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
v speeds | [email protected] | Piloting | 0 | July 11th 05 05:27 PM |
2-32 Speeds? | John Seaborn | Soaring | 1 | March 7th 04 03:49 AM |
Horton STOL 172 "V" speeds | R. Wubben | Owning | 6 | December 30th 03 02:04 AM |
Horton STOL 172 "V" speeds | R. Wubben | Piloting | 4 | December 30th 03 02:04 AM |
Winch Loads / Speeds data? | Gary Emerson | Soaring | 1 | December 17th 03 08:59 AM |
