2-32 Speeds?
Old March 6th 04, 08:25 PM
John Seaborn
Default 2-32 Speeds?
The SGS 2-32 has two categories of critical speeds, the "High
Performance" and "Utility" depending on gross weight.
Looking through the flight manual I see that at 1430lb max gross
Utility Category stall is estimated at 47mph. Red Line in this
category is 139 mph. What I do not see is the Caution Range starting
with the Max Structural Cruising speed (start of yellow arc). Max
aero tow is 110 mph and max ground launch is 86 mph.
Any ideas on the speeds for the start of yellow Caution Range for the
2-32 in Utility mode?
Speeds for best range or endurance don't depend on altitude John T Lowry Piloting 5 April 16th 04 03:02 AM
FLIGHT MANUAL AND/OR COMMON SPEEDS needed ! Ch. Bigalke Soaring 5 January 14th 04 03:10 AM
Horton STOL 172 "V" speeds R. Wubben Owning 6 December 30th 03 03:04 AM
Horton STOL 172 "V" speeds R. Wubben Piloting 4 December 30th 03 03:04 AM
PW-5 aero tow speeds Mike McCarron Soaring 3 August 24th 03 03:27 AM
