V-22 Prop Configuration, 3-vs-4 blades
Old March 24th 06, 03:11 PM posted to rec.aviation.military.naval,rec.aviation.military
Default V-22 Prop Configuration, 3-vs-4 blades
Why did they settle on the 3-blade configuration? Wouldn't a 4-bladed
system allow for a smaller footprint on the ground (or ship)? Or is
there too much thrust loss involved?
Old March 24th 06, 04:01 PM posted to rec.aviation.military.naval
Well, you can bet your arse that all configs were considered,
number of blades, length pitch width of blades, RPM range etc
etc...That a/c is a real departure from the conventional and must
have been a real headache to design and proove. I hope that they
now have a safe aircraft, they sure had their teething problems
didn't they?...
-Gord.
(use gordon in email)
Old March 24th 06, 03:50 PM posted to rec.aviation.military.naval,rec.aviation.military
"Don McIntyre" wrote in message
I would suspect it is a compromise due to the amount of force that has to be
applied through comparatively small components and the strength of the
materials out of which those components can be built.
Andrew Chaplin
SIT MIHI GLADIUS SICUT SANCTO MARTINO
(If you're going to e-mail me, you'll have to get "yourfinger." out.)
Old March 24th 06, 04:45 PM posted to rec.aviation.military.naval,rec.aviation.military
I would think folding 3 blades would be easier and lighter than
folding 4.
Dan, U.S. Air Force, retired
Old March 25th 06, 02:59 AM posted to rec.aviation.military.naval
folding 4.
?? Folding ??
-Gord.
Old March 25th 06, 11:38 AM posted to rec.aviation.military.naval
"Gord Beaman" wrote in message
folding 4.
?? Folding ??
-Gord.
http://www.paravion.com/products/407...e_fold_kit.htm
Keith
Old March 25th 06, 05:07 PM posted to rec.aviation.military.naval
folding 4.
?? Folding ??
-Gord.
Keith
Thanks Keith...I thought that Dan was referring to the V-22...I
don't think that it 'has' folding blades does it?...
-Gord.
Old March 25th 06, 05:21 PM posted to rec.aviation.military.naval
folding 4.
?? Folding ??
-Gord.
Keith
Yep, it sure does. If you could ever describe an aircraft as folding up
like a pretzel, the V-22 is it:
http://www.globalsecurity.org/milita...d-wing-seq.htm
Old March 24th 06, 11:15 PM posted to rec.aviation.military.naval,rec.aviation.military
More blades = less efficiency.
Shorter blades = less efficiency in vertical flight.
They probably couldn't have absorbed the performance loss from both
increasing the number of blades and reducing blade length.
KB
Old March 25th 06, 02:04 AM posted to rec.aviation.military.naval,rec.aviation.military
KB
How does more blades equal less efficiency? If that is true why do all
current Helicopters use 4-5 blades instead of two like the legacy
systems of the Huey and Cobra? Why do all modern turbo-props have more
then two blades? Somthing sounds off here. Guesses are like.... Anyone
actually involved in the engineering of the V-22 or at least privy to
some of the original evaluation documentation?
Reed
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Ivo Prop Blades - question Dave S Home Built 6 August 26th 05 04:20 AM
Sport Prop blades needed Ron Aviation Marketplace 0 February 19th 04 11:12 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
