Ivo Prop Blades - question
Old August 24th 05, 03:03 AM
Dave S
Default Ivo Prop Blades - question
This may be a silly question, but at the moment I am having a difficult
time visualizing this in my head...
Are the IVO prop blades able to be "reversed" with regards to direction
of rotation (counter-clockwise to clockwise) and still provide thrust
properly..?
Dave
Old August 24th 05, 04:16 AM
Dean A. Scott
properly..?
No. They have a pre-molded-in twist for right or left hand rotations.
The extra twist (+ or -) via the cam does nothing to the pre-twisted
root... just the outer 30% of the blades.
Even if you flipped them over, they have an airfoil profile that will
cease to be of any useful effect in generating full thrust... like
flipping a wing upside down... just won't create the proper lift.
Dean A. Scott, mfa
School of Visual Art and Design
southern adventist university
http://www.southern.edu/~dascott
Old August 24th 05, 04:52 AM
Morgans
"Dave S" wrote in message
properly..?
No one else is biting, so I'll shoot.
Even if you can turn them all of the way around, the camber of the airfoil
would be backwards. Although you would get some thrust, it would be at the
cost of a GREAT loss of efficiency.
Old August 24th 05, 05:27 AM
abripl
.... like flipping a wing upside down... just won't create the proper lift.
Yes it would be like mounting the left wing upside down on the right
side and vice versa.
Old August 24th 05, 02:19 PM
Dave S
Thanks,.. again I apologize if it sounded bone-headed.. I needed to
validate something with the group.
I appreciate the response,
Dave
properly..?
Dave
Old August 24th 05, 10:48 PM
On Wed, 24 Aug 2005 02:03:36 GMT, Dave S
properly..?
Dave
No. Wish they could be.
Old August 26th 05, 04:20 AM
Dave
properly..?
Dave
You don't need an aerodynamically efficient shape in order to generate
lift or thrust, but you do need a positive angle of attack. Even a flat
1x6 pine board will generate lift that way. Seems to me the Ivoprop
would work backwards, but not well.
my 2 cents.
DaveR
Sensenich Wood Prop Question [email protected] Owning 3 April 4th 05 02:32 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
p3/95 [email protected] Military Aviation 1 September 27th 04 12:27 AM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 06:19 PM
