Non-radar transponder codes
Old February 7th 04, 07:44 PM
Michael
Default Non-radar transponder codes
I am planning a trip into the Caribbean. My question is: If I have
been given a clearance from a non-radar facility. Because the
facility does not have radar they do not give me a transponder code.
What should I squawk? The same question applies to coming into a
radar-controlled environment from a non-radar environment like
approaching San Juan from Bermuda. Again, what should I squawk prior
to receiving a transponder code from San Juan? I was thinking that
the answer would be 1200 but the AIM says that 1200 is for VFR traffic
in the United States. Should you know the answer, I would also like
to know from where I can find the answer.
Thanks for the help ... Michael
Old February 7th 04, 09:19 PM
Steven P. McNicoll
"Michael" wrote in message
om...
If you're departing from a point in the US you should be assigned a beacon
code, even if your departure point is not served by radar. Beacon codes are
generated by ARTCC computer based on the equipment suffix you filed. If the
suffix indicates you have a transponder, a code is generated. If the suffix
indicates you do not have a transponder, or no suffix is entered at all, no
code is generated.
Old February 8th 04, 01:40 PM
om...
code is generated.
And, once you depart domestic FAA control and are handed off to oceanic you are
expected to squawk 2000. That is an ICAO rule.
Old February 9th 04, 04:56 AM
Steven P. McNicoll
"Brad Z" wrote in message
news:XkwVb.254738$na.416430@attbi_s04...
TCAS?
How does the beacon code affect TCAS performance?
Old February 8th 04, 08:24 PM
John R Weiss
"Roy Smith" wrote...
If you're out of radar coverage, why does anybody care what you squawk?
While you may be out of range of ATC radar, "Big Brother" may be watching with
even bigger radars (e.g., Shemya)...
Old February 8th 04, 08:55 PM
John R Weiss
The answer is: "2000" -- at least for oceanic operations.
I just ran across AC 91-70B -- Oceanic Operations, dated 09/06/94, at
http://www1.faa.gov/fsdo/orl/files/advcir/AC9170B.TXT.
Chapter 2, OCEANIC OPERATIONS FOR ALL AIRCRAFT IN ALL GEOGRAPHIC AREAS, par
6.e(4) states:
(4) ICAO Documents 7030, "Regional Supplementary Procedures"
and 8168, "Aircraft Operations Volume I," state that
transponders shall be operated as follows:
(a) when the aircraft carries serviceable Mode C
equipment, the pilot shall continuously operate in
this mode, unless otherwise directed by ATC;
(b) in NAT airspace, unless otherwise directed by ATC,
pilots shall retain the previously assigned
transponder code for a period of 30 minutes after
entry into the airspace, then operate on code 2000;
(c) in oceanic airspace other than the NAT, pilots shall
operate the transponder and select modes and codes as
directed by the ATC unit with which the pilot is in
contact; or
(d) in the absence of any ATC directions, pilots shall
operate the transponder on Mode A Code 2000.
Further, in Chapter 3, par 9.g, discussing non MNPS airspace over the Atlantic:
Navigation equipment adequate for operation in accordance
with the flight plan and with ATC clearances shall be
carried. SSR transponders with Mode 3/A and C are required in
Iceland. Pilots shall operate SSR transponders continuously
on Mode A, Code 2000. Departing aircraft shall retain the
last assigned code for 30 minutes after entry into NAT
oceanic airspace unless otherwise instructed by ATC. This
procedure does not affect the use of special purpose codes
7500, 7600 or 7700 when required.
Chapter 4, par. 4.g (Northern Pacific ops):
g. Transponder Codes. When operating west of l64E, transponders
should be set to Mode A Code 2000. When east of 164E, a
discrete code may be assigned. This code should be maintained
unless otherwise advised by ATC. If no discrete code is
assigned, transponders should be set to Code 2000.
Chapter 11, GENERAL AVIATION SHORT-RANGE AIRCRAFT OCEANIC OPERATIONS, par. 2.j,
says this about transiting Iceland:
Navigation equipment adequate to navigate in accordance with
the flight plan and in accordance with ATC clearances will be
carried aboard the aircraft. Secondary surveillance radar
(SSR) transponders with Mode 3/A and C are required in
on Mode A, Code 2000, except that departing aircraft shall
retain the last assigned code for 30 minutes after entry into
NAT oceanic airspace unless otherwise instructed by ATC.
Old February 9th 04, 05:22 PM
B. Jensen
Exactly...someone is usually watching somewhere regardless of where you
are.
I used to laugh in the 80's & early 90's when I was flying over Cuba on
a regular basis. Havana would always tell me that radar service was
terminated and then require verbal position reports while we all knew
they were tracking us closely on their radar. Now that things are
"friendlier" with them, we are always in radar contact....amazing....
"Radar service terminated" doesn't mean someone...somewhere...isn't
watching.
BJ
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
Ham sandwich navigation and radar failure David Brooks Instrument Flight Rules 47 December 31st 03 12:15 AM
transponder check? Russell Duffy Home Built 10 August 14th 03 11:36 PM
Marine Radar in a plane? Jay Honeck Home Built 31 August 13th 03 06:56 PM
