VHF & Transponder antenna
Old December 6th 04, 04:32 AM
Steve
Default VHF & Transponder antenna
I bought a Cassutt (Primarily tube, fiberglass and fabric). It has a
light-weight BNC battery, starter and alternator, and a old Grand
Rapids engine monitoring system but no radios. I wish to install a
panel mounted MicroAir Radio and Transponder. I think I can figure out
the wiring of the radios but the only aluminum on the airplane is a
12"X11" aluminum belly pan.
Can I use this as a ground plane for both the VHF and transponder
antennas? If so, where should I position them with respect to each
other and the edge? With regard to the antennas, a transponder antenna
came with the MicroAire Transponder, and I plan to purchase a VHF
antenna from aircraft spruce. Aircraft spruce however, has many
different designs, brands and of course prices. Which one would give
me the best performance for my application? I have about 21" from the
belly pan to the ground in the three point position.
Any help you could give will be greatly appreciated
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 04:27 PM
Spare Transponder Antenna? Jim Weir Home Built 6 May 25th 04 04:34 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 01:18 AM
Wanted: Transponder antenna Grandpa B. Home Built 22 November 28th 03 09:03 AM
